• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk PLM 360
    Uploading items Error
    89 Views, 6 Replies
    01-04-2013 09:39 AM
    When I try to upload data from an excel file I get this warning "The validator "Money" of field Travel Cost is not supported."
    I have a PLM data type as "Money" and have tried formatting my cells in excel as Number or Currency.  Will I need to change my PLM data type in order to import this data?
    Please use plain text.
    Re: Uploading items Error
    01-04-2013 12:35 PM in reply to: sdibben
    I was able to get the import to work, but only by changing all data types to "Single Line Text".  After the import I edited the field and changed it back to "Money".  Not ideal, but I was able to complete the import.
    Product Support
    01-08-2013 06:31 AM in reply to: sdibben
    Scott,
    Sorry about taking so long to get back to you but by chance did the money values have a sign (ie. '$') attached to them by chance?
    Joe Piggee
    Support Specialist
    Product Support
    01-11-2013 11:37 AM in reply to: sdibben
    No $ attached.  It looks like PLM will not allow the field that data is coming into to be of Data Type "Money".  It may have to do with the validation for that field.  If you switch it to slngle line text it works.  After the import I went back and then changed the field back to Data Type "Money"
    Product Support
    Andrew.Shaw
    01-14-2013 05:46 AM in reply to: sdibben
    Dear Scott,
    I have just tried importing values in a Money field and have encountered no error.
    Could you provide me with the steps to recreate your issue, including a screenshot of the settings for the money field and an excel sheet containing values to be imported?
    Best regards,
    Andrew Shaw
    Premium Support Specialist PLM/PDM
    Global Services
    01-21-2013 12:36 PM in reply to: sdibben
    I apologize, it does seem to be working now.  I was not able to get the import to load files one afternoon.  I have since tried and was able to upload into a money field.
    Product Support
    01-22-2013 09:53 AM in reply to: sdibben
    Good to hear that it is working now, (did you do anything different this time around?)
    And thank you for the update.
    Joe Piggee
    Support Specialist
    Product Support
