• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk PLM 360
    *Expert Elite*
    ScottMoyse
    PLM 360 Sync error 200
    94 Views, 1 Replies
    09-20-2012 05:00 AM
    RIght I can't work out what the problem is here: Can you guys help:
    PLM/Vault synchronization on machine MOYSEPC1 failed: One or more errors occurred.
    ----- details -----
    System.AggregateException: One or more errors occurred. ---> System.Net.WebException: Expected status code of 200.
       at Autodesk.Dms.WebServices.Service.ThrowOnBadStatus(XName name, HttpWebResponse response, Int32 expectedStatus)
       at Autodesk.Dms.WebServices.AuthenticationService.DoLogin(String user, SecureString password)
       at Autodesk.Dms.WebServices.UserPasswordCredentials._LogOn(AuthenticationService secSvc)
       at Autodesk.Dms.WebServices.TenantManager.LogOn()
       at System.Threading.Tasks.Task.Execute()
       --- End of inner exception stack trace ---
       at System.Threading.Tasks.Task.Wait(Int32 millisecondsTimeout, CancellationToken cancellationToken)
       at Autodesk.Plm.VaultSync.SyncClient.SyncPlmSession.LogOn()
       at Autodesk.Plm.VaultSync.SyncClient.VaultToPlm.GetSession(SynchronizationEntry entry)
       at Autodesk.Plm.VaultSync.SyncClient.VaultToPlm.PushJob(SyncJob job)
       at Autodesk.Plm.VaultSync.SyncClient.VaultToPlm.ProcessJob(SyncJob job)
    ---> (Inner Exception #0) System.Net.WebException: Expected status code of 200.
       at System.Threading.Tasks.Task.Execute()<---
    PLM/Vault synchronization on machine MOYSEPC1 failed: entity=[Window Return Id=444586].PushEntityToSession(session=[506 NISI 2 Released Items - SMITemp])
    ----- details -----
    System.InvalidOperationException: entity=[Window Return Id=444586].PushEntityToSession(session=[506 NISI 2 Released Items - SMITemp]) ---> System.AggregateException: One or more errors occurred. ---> System.InvalidOperationException: Modified On is not a valid date. ---> System.Net.WebException: The remote server returned an error: (400) Bad Request.
       at System.Net.HttpWebRequest.GetResponse()
       at Autodesk.Dms.WebServices.HttpWebRequestExtensions.<>c__DisplayClass1.<GetHttpResponse>b__0()
       at Autodesk.Dms.WebServices.Service.CatchProtocolErrorWebException[T](Func`1 action, Func`2 handler)
       at Autodesk.Dms.WebServices.HttpWebRequestExtensions.HandleError(WebException wex)
       at Autodesk.Dms.WebServices.HttpWebRequestExtensions.GetHttpResponse(HttpWebRequest request, String method, Action`1 useRequestStream, String contentType)
       at Autodesk.Dms.WebServices.ItemCreator.Post(Uri requestUri, XDocument content)
       at Autodesk.Dms.WebServices.ItemCreator.Add(String alias, Entry[] metaFields)
       at Autodesk.Dms.WebServices.ItemService.AddItem(String alias, Entry[] metaFields)
       at System.Threading.Tasks.Task`1.InvokeFuture(Object futureAsObj)
       at System.Threading.Tasks.Task`1.get_Result()
       at Autodesk.Plm.VaultSync.SyncClient.SyncPlmItemService.AddItem(String alias, Entry[] metaFields)
       at Autodesk.Plm.VaultSync.SyncClient.PushSyncSession.AddItem(String alias, Entry[] metaFields)
       at Autodesk.Plm.VaultSync.SyncClient.PushSyncSession.GetOrCreatePlmItem(String alias, Entry[] metaFields)
       at Autodesk.Plm.VaultSync.SyncClient.PushSyncSession.Pu****emRevisionInBOM(SyncItem syncItem)
       at Autodesk.Plm.VaultSync.SyncClient.SyncItemRevisionOperation.Execute(OperationManager mgr)
       at Autodesk.Plm.VaultSync.SyncClient.OperationManager.Run(ISyncOperation operation)
       at Autodesk.Plm.VaultSync.SyncClient.VaultToPlm.PushEntityToSession(SyncEntity syncEntity, SyncPlmSession session)
    I used to have this working with the first version of the Sync tool. I uninstalled it, installed this one & now it doesn't work. I've tried different log ons & turning the visualisation option on & off but no joy.
    Please help
    Cheers
    Scott Moyse
    Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Cheers!
    Please use plain text.
    Product Support
    michelle.stone
    Re: PLM 360 Sync error 200
    09-20-2012 08:14 AM in reply to: ScottMoyse
    Scott - I'll create a case and work with you on this.
    Cheers,
    Michelle
    Michelle Stone
    PLM Product Manager
    Autodesk, Inc.
