• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk PLM 360
    *Expert Elite*
    ScottMoyse
    Nice scripting error for you guys
    81 Views, 7 Replies
    10-04-2012 12:27 PM
    On creating an Item I got the following scriting error:
    Since it made no sense to me & didn't appear to point to anything wrong with my script, i decided to try & create the item again. It worked... But its the longest 'scripting' error I've seen so far so I thought I'd share my landmark moment. :smileyhappy:
    Cheers
    Scott Moyse
    Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Cheers!
    Please use plain text.
    Product Support
    Re: Nice scripting error for you guys
    10-04-2012 12:31 PM in reply to: ScottMoyse
    Hi Scott,
    Mind posting the script(s) you were using JAVA and computed fields.
    Joe Piggee
    Support Specialist
    Product Support
    Autodesk, Inc.
    *Expert Elite*
    ScottMoyse
    10-04-2012 12:47 PM in reply to: piggeej
    item.NUMBER = item.PROJECT.CONTRACT_NUMBER + "-" + item.DECK + "-" + item.AREA;
    if (item.AREA <= 9)
    {item.WORK_PACK_NUMBER = item.DECK + "0" + item.AREA;}
    else
    {item.WORK_PACK_NUMBER = item.DECK + item.AREA;}
    //=========== sets the related product's Work Allocations ======================//
    setLists();
    //=========== sets the current Items Number ======================//
    item.NUMBER = item.RELATED.CONTRACT_NUMBER + "-" + item.DECK + "-" + item.AREA;
    if (item.AREA <= 9)
    else
    Cheers
    Scott Moyse
    *Expert Elite*
    ScottMoyse
    10-04-2012 12:48 PM in reply to: ScottMoyse
    setlists:
    function setLists(){
    var desc = item.descriptor.descriptor;
    var tempProduct = null;
    if(item.RELATED_TEMP === null){
    item.RELATED_TEMP = item.RELATED.descriptor.descriptor;
    else if (item.RELATED === null && item.RELATED_TEMP !== null){
    tempProduct = new parentObject(item.RELATED_TEMP.descriptor.dmsID);
    tempProduct.removeItem(desc);
    item.RELATED_TEMP = null;
    else if(item.RELATED.descriptor.descriptor !== item.RELATED_TEMP.descriptor.descriptor){
    //item.RELATED_TEMP.RELATED_WORK_ALLOCATIONS = removeItem(item.RELATED_TEMP.RELATED_WORK_ALLOCATIONS, item.descriptor.descriptor);
    }//end if
    if(item.RELATED !== null){
    var product = new parentObject(item.RELATED.descriptor.dmsID);
    product.addItem(desc);
    }//end if
    function parentObject(dmsID){
    this.myObject = loadItem(dmsID);
    this.addItem = function(descriptor){
    if(this.itemExists(descriptor) === false){
    var currentValues = this.returnItems(descriptor);
    currentValues.push(descriptor);
    this.myObject.RELATED_ITEMS = currentValues;
    this.itemExists = function(descriptor){
    if(this.myObject.RELATED_ITEMS === null){return false;}
    for (var i = 0; i < this.myObject.RELATED_ITEMS.length; i++) {
    if(descriptor === this.myObject.RELATED_ITEMS[i].descriptor.descriptor){
    return true;
    return false;
    this.returnItems = function(){
    var currentValues = [];
    if(this.myObject.RELATED_ITEMS === null){return currentValues;}
    currentValues.push(this.myObject.RELATED_ITEMS[i].descriptor.descriptor);
    this.removeItem = function(descriptor){
    if(descriptor !== this.myObject.RELATED_ITEMS[i].descriptor.descriptor){
    Cheers
    Scott Moyse
    *Expert Elite*
    ScottMoyse
    10-04-2012 12:51 PM in reply to: ScottMoyse
    There's one computed field in the item details:
    BUDGET_HOURS-HOURS_TO_DATE
    Cheers
    Scott Moyse
    Product Support
    michelle.stone
    10-04-2012 01:14 PM in reply to: ScottMoyse
    Scott - I just came across pretty much the same error in another tenant.  Will report.
    And same as you - retrying worked.
    Michelle
    Michelle Stone
    PLM Product Manager
    Autodesk, Inc.
    Product Support
    10-04-2012 01:21 PM in reply to: ScottMoyse
    Scott,
    Looks like an issue with stamping userids to the logging section on item creation, checking with the powers to be right now.
    Joe Piggee
    Support Specialist
    Product Support
    Autodesk, Inc.
    *Expert Elite*
    ScottMoyse
    10-04-2012 01:31 PM in reply to: piggeej
    sweet :-) glad i reported it then
    Cheers
    Scott Moyse
