• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk PLM 360
    Active Contributor
    Import and update contacts
    102 Views, 5 Replies
    04-24-2012 02:35 AM
    I have created a "Contact" workspace, I have imported some contacts (firstname, lastname and e-mail) in this workspace and would like to "reimport" an updated list of contacts (same firstname and lastname but some e-mail have been changed)... When I do so, PLM360 never update my contact but recreate new contacts...
    Am I doing somthing wrong???
    Xavier
    Xavier
    Please use plain text.
    Product Support
    Re: Import and update contacts
    04-24-2012 03:50 AM in reply to: xcollet
    Please choose "Match On" option to update the existing value. Attached image is for your reference.
    Madhan
    If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
    Madhanagopal Thiruvenkatachalam
    Support Specialist
    Product Support
    Active Contributor
    04-24-2012 04:50 AM in reply to: Madhan_T_autodesk
    Great it works fine!
    Xavier
    Employee
    broepke
    04-24-2012 06:46 AM in reply to: xcollet
    Xavier,
    Another thing I've learnt thorugh experience is to ALWAYS have an Autonumber field on all your workspaces.  Even if it's something you just put at the bottom of the form.  This makes is so much easier to import and match data with exact accuracy later.  While you can match on multiple values - you still might have two people with the same name in your contact list.
    This is simple - you can add it any time you want - even after records are created - just go to setup and add a single auto-number filed.  It will prefex it with two letter - you can see all over the workspaces we've changed these to a two letter abbreviation for whatever your working on  - "CN" or "CT" or whatever you want.  Makes it easy to identify (doesn't have to be globally unique)
    Brian Roepke
    Director of Product Lifecycle Management
    Active Contributor
    04-24-2012 07:46 AM in reply to: xcollet
    Hi Brian,
    I do agree with you,... and I would do the same on a production workspace... but I am just doing "quick and dirty" tries. ;o)
    Xavier
    Xavier
    Employee
    broepke
    04-24-2012 07:55 AM in reply to: xcollet
    Great to explore - finding this "key match" is a great trick!
    Brian Roepke
