When creating a Google maps Computed Field, can you use a Pick List to define a value in one of the fields?
Solved by JohnCHill. Go to Solution.
Yes, but you would have to do advanced scripting because in the computed field the Pick List will return the index of the field and not the value. At this time Single Lined Text is the best option.
