• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk PLM 360
    Active Contributor
    Accepted Solution
    Error using google map and pick list
    153 Views, 9 Replies
    04-25-2012 10:56 PM
    I have a workspace in which I defined an address section containing a "Country" field being a pick list.
    I add to this workspace a Google map field (an exact copy of what is done in the suppliers workspace) I can save those settings but when I go to my Workspace, I get an error (see attached file).
    Xavier
    Xavier
    Please use plain text.
    Employee
    Re: Error using google map and pick list
    04-26-2012 09:01 AM in reply to: xcollet
    Hi Xavier,
    That's a great question that requires digging a little into the technology to understand. The short answer is that you cannot use Computed Fields with Pick Lists as the value from the Pick List is only stored as a reference to another table in the DB and not as the text string that you expect.
    That said, the field behaves exactly as you expect it to behave in Scripting. So an alternative solution to your problem will be to write an Action Script that will compute the result of the Google Maps mesh-in and will write it to the Map field. You can have this script run on Creation and/or Edit of the item to cover your particular use case.
    Hagay Dvir
    Product Manager
    Product Lifecycle Management
    Autodesk, Inc.
    Product Support
    04-26-2012 09:51 AM in reply to: xcollet
    Hi Xavier,
    I have found this out as well, however as an alternative I found that I could use the non-pick list fields to feed the information in to the Google mapping script and leave out the pick list field.  This will eliminate the error that your seeing.
    I have noticed for the most part Google will be able to accurately find the Country based on the zip code provided.
    Joe Piggee
    Support Specialist
    Product Support
    Autodesk, Inc.
    Active Contributor
    04-27-2012 01:22 AM in reply to: piggeej
    I have made this script :
    item.MAP = '<iframe width="425" height="350" frameborder="0" scrolling="no" marginheight="0" marginwidth="0" src="http://maps.google.com/maps?f=q&amp;source=s_q&amp;hl=en&amp;q=' + item.RUE_ET_NO + ',' + item.VILLE + ',' + item.PAYS + ';t=h&amp;z=14&amp;output=embed"></iframe>'
    I run it each time the record is saved... It works well except that I have to refresh (F5) the page after save...
    Xavier
    Xavier
    Employee
    04-27-2012 07:50 AM in reply to: xcollet
    Xavier,
    That is an interesting behavior. I tried it on my system just to be sure and I don't experience the need to refresh the screen after edit. What browser are you using? I am using Chrome here.
    Hagay.
    Hagay Dvir
    Product Manager
    Autodesk, Inc.
    Active Contributor
    04-27-2012 08:49 AM in reply to: dvirh
    I also use Chrome...
    Google Chrome (18.0.1025.162m)
    See attache video to see the exact behavior I have
    Xavier
    Product Support
    04-27-2012 09:04 AM in reply to: xcollet
    Xavier,
    I also do not experience this behavior in Chrome. By any chance you have a behavior script setup for this workspace as well?
    Joe Piggee
    Support Specialist
    Product Support
    Autodesk, Inc.
    Employee
    04-27-2012 09:14 AM in reply to: xcollet
    Xavier,
    OK, the behavior is not consistent but I was able to reproduce it and will be reporting it as a bug. For now, F5 is the workaround...
    Thanks for helping to find this bug!
    Hagay.
    Hagay Dvir
    Product Manager
    Autodesk, Inc.
    Active Contributor
    04-29-2012 11:32 PM in reply to: xcollet
    Thanks!!!
    The workaround is ok for now!
    Xavier
    Employee
    04-30-2012 02:15 PM in reply to: xcollet
    Xavier,
    Some additional information about this problem for the benefit of everybody on the forum. NOTE: all browser references below relate to the latest release of that browser.
    We were able to pinpoint the issue to a knwon bug with webkit, which is the engine behnid Chrome and Safari. The problem does not reproduce on other browsers I've tested including IE, FireFox and Opera. In IE, you actually get a message on each and every view of a page that includes such content, to approve viewing the 'unsecured content'. If you approve it, the page refreshes and the problem does not appear. However, this means that IE gives you the worst user experience in this case.
    We also came up with a workaround the the above problem that will be released in an upcoming release of PLM 360. I have already tested this fix in our QA environment and it seems to work great.
    Hagay Dvir
    Product Manager
    Autodesk, Inc.
