• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk PLM 360
    Derived Image Field
    40 Views, 1 Replies
    09-19-2012 09:07 AM
    Are derived fields not intended to work with images, or is there a known bug?  I've added a derived field is meant to pull an image field from another workspace.  The image will preview when editing the item, but after saving, the image does not show.
    Editing the item:
    After saving the item:
    Please use plain text.
    Product Support
    Re: Derived Image Field
    09-19-2012 10:50 AM in reply to: CodeMonkey831
    Hi Jason,
    Thanks for the info, but as you mentioned, yes derived fields are only supporting text based input at this time. However this might be expanded in the future.
    Joe Piggee
    Support Specialist
    Product Support
