• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk PLM 360
    Derived Field - Linked picklist with filter
    55 Views, 1 Replies
    10-08-2012 12:46 PM
    Hello, I try to use great function :smileywink: for derived information (field) from another item, but not working.
    If I create new field (for example "Customer") data type "Linked pick list" and in the specifications this data type I chose "With search filter". Next I create second new field (for example "Phone number") and chose data type "derived" and there I chose from my linked "Customer" field. After that when I try to create new Item with this combinations field "Customer" not working, I can´t select some record.
    What I try to say is, that in this combination I can´t use Field "Customer" like linked picklist with filter. This field not working.
    I don´t know what I do bad or maybe in this specified combination is not possible.
    Thanks for help and answare.
    Please use plain text.
    Product Support
    Re: Derived Field - Linked picklist with filter
    10-08-2012 02:56 PM in reply to: roman.kovarik
    Hi Roman,
    At this point derived fields are only compatible with single select Linking pick list, please adjust your pick list and try again.
    Joe Piggee
    Support Specialist
    Product Support
    Autodesk, Inc.
