• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk PLM 360
    Valued Contributor
    obourne
    Customizing UI - Item Details
    70 Views, 2 Replies
    11-15-2012 11:02 AM
    Is there a way to customize the layout of the Item Details tab? Currently I see the fields stacked top to bottom. I want to be able to arrange the field display as a form and input data that way. This would be a parallel to enetring in data on a PDF document.
    The attached file shows a document I cutrrently use. I'd like to migrate this to 360 but keep the current layout.
    Please use plain text.
    Product Support
    Re: Customizing UI - Item Details
    11-15-2012 11:40 AM in reply to: obourne
    When you are building the Item Details Fields for your workspace try using a Matrix.  With the Matrix you can move fields from left to right on the Item Details tab and I have created multiple workspaces based on a PDF document.
    Hope this helps,
    John
    John Hill
    Support Specialist
    Product Support
    Valued Contributor
    obourne
    11-15-2012 04:00 PM in reply to: JohnCHill
    I checked it out. It's OK. I would prefer full on customization but can probably make it work as is.
    Thanks for the tip. :smileyhappy:
