• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk PLM 360
    Active Member
    Accepted Solution
    Change owner or add owner by script
    101 Views, 3 Replies
    12-05-2012 08:20 PM
    Hi All,
    i want to be able to have an item field (user picklist) called something like "Assinged to" and on creation of that item ownership is changed to the person specified in the Assinged to Field. i wouldnt mind if this person was added to the additional items either just as long as they are considered an owner of the task.
    i want this so that when i assign a task to someone others cant see there tasks (permisions "View Records owned by others), this is mostly because i want to clean up the outstanding work section of the home screen. right now everyone can see the task even if they are not responsible for it.
    i dont mind if there is a simple answer to this that doesnt need scripting however i dont think there is.
    Cheers,
    James Tennent
    Please use plain text.
    Product Support
    michelle.stone
    Re: Change owner or add owner by script
    12-07-2012 04:44 PM in reply to: jamest
    James - it's not possible to update the owner or add additional owners through scripting currently.  One way we deal with this is like you mentioned - remove the 'View Records Owned by Others' permission from the workpace and have the record creator add specific groups or users to the additonal owners:
    Michelle
    Michelle Stone
    PLM Product Manager
    Autodesk, Inc.
    Distinguished Contributor
    12-09-2012 04:14 AM in reply to: jamest
    Hi James,
    I'll also need to be bale to have this functionality in the future. Have you posted this proposal in IdeaStation?
    David.
    Active Member
    12-20-2012 09:22 PM in reply to: dkeeley
    this has now been added to the idea station, hit the kudos to give it some legs if you like.
