• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk PLM 360
    Distinguished Contributor
    Accepted Solution
    Change Milestone State using scripting
    139 Views, 15 Replies
    01-05-2013 05:29 AM
    I want to be able to change the workflow state referenced by a milestone via scripting. The WikiHelp seems to suggest this is possible but I have not been able to get it to work. My script is as follows;
    item.milestones[0].setWorkflowState('[99] Cancelled');
    The Wikihelp states the following;
    Methods on the Milestones Array
    milestones.setWorkflowState("SHORT_NAME")
    Method to set the workflow state associated with the milestone (milestones.workflowState). The "SHORT_NAME" parameter takes the value for the milestones.workflowState.shortName property.
    Can you please let me know what I'm doing wrong?
    David.
    Please use plain text.
    Re: Change Milestone State using scripting
    01-05-2013 02:07 PM in reply to: dkeeley
    Also,
    is it possible to change a milstone date after it has been created using scripting?
    David.
    Product Support
    01-07-2013 07:07 AM in reply to: dkeeley
    David,
    Workflow states dictate milestones, not the other way around. You can have a workflow state create or adjust a milestone, or look at a milestone for a condition of validation, but you cannot have a milestone adjust a workflow state.
    Also yes you can adjust a milestone date via scripting after the milestone is created, if you know the name of the milestone your trying to affect.
    Joe Piggee
    Support Specialist
    Product Support
    Autodesk, Inc.
    01-07-2013 07:29 AM in reply to: piggeej
    Hi Joe,
    Thanks for the reply. So if I understand you correctly it is not possible to change the workflow state asscoiated to an existing milestone via scripting?
    David.
    Product Support
    01-07-2013 07:38 AM in reply to: dkeeley
    David,
    There isn’t a way for a script to start based on when a milestone changes. Scripts only work on workflow changes or item creation / change.
    Joe Piggee
    Support Specialist
    Product Support
    Autodesk, Inc.
    01-07-2013 07:41 AM in reply to: piggeej
    Joe,
    I think we have our wires crossed. The script is executed by a workspace behaviour (edit). All I want to do is change the workflow state referenced by the milestone at that point.
    Does that clear things up?
    David.
    Product Support
    01-07-2013 08:06 AM in reply to: dkeeley
    David,
    If you are trying to change the workflow step based on a milestone. Then you are looking at an ‘if’ or 'case' statement and using:
                    item.performWorkflowTransition(transID, 'comments')
    Joe Piggee
    Support Specialist
    Product Support
    Autodesk, Inc.
    01-07-2013 08:32 AM in reply to: dkeeley
    Hi Joe,
    I think we still have our wires crossed ;-)
    I'll PM you to discuss further.
    David.
    01-07-2013 12:49 PM in reply to: dkeeley
    Hi Joe,
    I have tried to illustrate what I am trying to do on the attached document. Please let me know if this sheds any light.
    David.
    Product Support
    01-08-2013 06:28 AM in reply to: dkeeley
    David,
    Based on what your showing all you can do at that point is set the “Closed” milestone to completed at 100% and create a new milestone for “Cancel”.
    You cannot change one milestone for another or delete and replace the milestone by scripting.
    Joe Piggee
    Support Specialist
    Product Support
    Autodesk, Inc.
