Autodesk PLM 360
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Best way to import part lists
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have a simple question about the import. I generate an Excel spreadsheet with a list of parts and their attributes. I'd like to import the list and have the new parts generated.
Instead, it tells me the field Number is non-editable and will be blank. Sure enough, I end up with a bunch of parts that have blank part numbers, which I am then unable to edit.
Periodically, I'd like to import a list of parts, have existing attributes updated and any new parts created automatically. I'm sure there's a way to do this, but I couldn't get it to work. Thanks
Edward
Re: Best way to import part lists
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hello Edward,
Could you please provide the settings of the number field or, even better, a screen shot of the dialog box displayed when you edit that field (so that we can see all the settings without you having to type them again).
Best regards,
Andrew Shaw
Premium Support Specialist PLM/PDM
Global Services
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Edward,
There is no screenshot attached to your reply but let's try to see what the possible culprits are:
1. Is there a behaviour script that runs at item creation? Wiki link
2. Is it computed field? Wiki link
Best regards,
Andrew Shaw
Global Services
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I replied by e-mail; looks lile the attachments get pruned out. Let me try on the web page.
A script called "ItemSeqGen" runs at item creation.
The script is:
var itemSeqID = '333';
var newItemNumber = nextSeqNumber(itemSeqID);
if(newItemNumber !== null){
var catNumber = item.ITEM_CATEGORY.CATEGORY_CODE;
item.NUMBER = catNumber + '-' + newItemNumber;}
The item number is obviously a bit of a special field. It should not be editable in general and certainly never changed. Having it generated automatically by script is great. But when importing parts that have been created in the past, the numbers just have to be accepted as-is. Even if they don't conform to the numering schema, they can't be changed anymore.
I may be totally on the wrong path here. What's the best way to approach this? Thanks
Edward
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Are you choosing any key fields to 'match on' during the import? See section 4 of the tutorial. In the 'Import Message' screen shot I didn't see one. This will help identify which records exist already and will be updated rather than created.
Michelle Stone
PLM Product Manager
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
From the attachment (NumberFieldSettings.jpg) I noticed that "Editable" is set to "False". This is the default setting for Part Number. But, prior to import, this has to be set to "True".
Madhan
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Madhanagopal Thiruvenkatachalam
Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi, Madhan
I also thought perhaps I should toggle the Number field to editable. But, when I tried to do so, I got an error message that the field was already in use (see FieldInUseError.jpg). It appears I cannot change it.
Of course, making the field editable in general would be less desirable, but I could go in, toggle it, do my loading, then toggle in back. If I could get the Import to load it directly, I could set editable to "On Creation Only". This work-around would be sufficient, I guess.
Ideally, I'd like to have autonumbers for everyone on most part categories, just free-hand for certain ones. But, I'd like the component engineer or other select people to be able to import & create new part numbers of any form. I'd rather not grant those people admin privileges to tinker with the Number attribute, but I guess it could be sorted out organisationally.
I thought this was a simple use case, but I guess I opened a can of worms. Maybe it can't be done. I do appreciate everyone's attempts to help.
Edward
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Okay, I was able to set "Number" to editable on "Creation Only": I must have clicked on "Clone" instead of "Edit" before.
After doing that, I was able to run the import and get the parts created.
I actually ran it twice, and it created the parts twice (!). I then added a validation to the Number field to make it unique, and the import now catches it.
This will work well enough. Thanks everyone
