Fusion Manage Forum
Welcome to Autodesk’s Fusion Manage (formerly Fusion 360 Manage) Forum. Share your knowledge, ask questions, and explore popular Fusion Manage topics.
Attachement Preview?
4 REPLIES 4
fxding
620 Views, 4 Replies
Is the Autodesk 360 document preview feature gonna be supported in the PLM 360 too?
Tags (1)
4 REPLIES 4
scottmoyse
in reply to: fxding
I'm already using it by setting up an iFrame in a computed field within the item details tab, then passes it a url from a seperate item detail. It's not what i would call integrated into PLM 360 but it works.
Let me know if you need some code
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
fxding
in reply to: scottmoyse
Scott,
Thanks for the tip! I'd apperciate it if you can send me some sample codes.
-Frank fding AT strongtie DOT com
michelle.stone
in reply to: fxding
Methinks this might make a good Tip Tuesday bit in the coming weeks...  Scott - thanks for helping out Frank!
Michelle
Michelle Stone
Technical Marketing, PDM & PLM
Autodesk, Inc.
scottmoyse
in reply to: fxding
Sorry its taken so long:
'<iframe width="100%" height="1000" frameborder="0" scrolling="no" marginheight="0" marginwidth="0" src="' + INSERT URL HERE + '"></iframe>'
Create a Field with URL as the data type,
Create another field using the single line text as a data type and recreate the settings shown in the image below (using you rown field name):
Note: You add the code snippet above into the Computed Field Formula
then use that field ID for the URL field you created in the snippet of code above by over writing 'INSERT URL HERE'.
You can adjust the size of the iFrame by modifying the values within the code. The best bit about this code is its so flexible. Its just simple HTML, so you can embed or mashup a whole bunch of things from around the internet.
Again sorry it took so long. I hope this helps.
Cheers
Scott.
Scott Moyse
