In the PM tab there are a predefined set of columns. I want to be able to add/remove etc. columns and have them display meta data from linked items.
If I can do that I wont need to switch back and forth between workspaces and tabs to get the data I need to manage my project.
Anytime I can keep from bouncing around the tennant is time saved and goes towards reducing the perception that using a spread is better (because of less bouncing around).
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
