Have Project Management Available Through Scripting
Adding Project Management items in the Project Management tab is tedious at times. Being able to add project items through scripting would allow an automated procedure involving less time consumption and tedious routine work.
10 Comments
jared.sund
This is an item that's already on our list. I've added a link to this Idea Exchange to help give it a little more priority 🙂
scottmoyse
There is a slight workaround, if you aren't using it already. You can setup a relationship tab, create all your new task items via that, then when you go to the PM tab you can add linked items & just tick the ones you need to add. However, you still have to go to each individual task item & modify the milestones if they aren't how you would like them to be.
scottmoyse
Correction. You can actually do it all from the 'Add Linked Items' button in the PM tab.
Jared. This would be an extremely useful feature. Any ideas of timescales for when we could expect to see it?
jared.sund
Unfortunately I'm not able to comment on any time frames for the release of features in the product, however…  I can say that expanding the scripting engine’s reach into Project Management, relationships, workflow items, bom,  …., etc.  is a high focus of my scripting efforts.
jared.sund
We're part way there, read access to the project management tab has been added in the Feb. 2013 PLM 360 release.  We'll followup with write access to project mangement in scripting.
troy_hylton
Right now there is only read access, but write access is required as well.
jared.sund
Status changed to: 投票募集中
New read/write scripting access to project management is now available in the May 2013 PLM 360 release!
jared.sund
Here's a simple example of scripting to project management tasks:
//adds tasks to projects
if(item.PROJECT!== null){   // a picklist of projects on the tasks item details page.
     var taskExists = false;
     var project = item.PROJECT.project;
     //check to see if the task is already added to the project
     for(var i =0 ; i < project.subTasks.length; i++){
          if(item.descriptor.descriptor === project.subTasks[i].title){
               taskExists = true;
               break;
     if(taskExists === false){
           //add the task to the project
           item.PROJECT.project.addTask(item, new Date(), new Date(), 10);
Read:
item.project.<FIELD> where <FIELD> is: title, start_date, end_date, duration, progress, predecessors, subTasks, status, statusCode
item.project.subTasks[i].<FIELD> where <FIELD> is: id, title, start_date, end_date, duration, progress, predecessors, subTasks, children, status, statusCode, owner, target, isReadOnly
Write:
item.project.addTask("Task Name", startDate, endDate, progressPct); // Free-form text task
item.project.addTask(targetItem, startDate, endDate, progressPct); // Item linking task or milestone task
nguyentru
