Allow a BULK IMPORT of Attachments
It is highly tedious and annoying to attach a pdf or a dwg file to a list of items in a workspace. Having the ability to bulk upload attachments to specific items in a workspace would be ideal for mass drawing updates or file updates.
One solution would be importing a zip file of the attaching files and an excel file that would have the item descriptor in one column and the corresponding file name in the other column.
10 Comments
jared.sund
I totally agree.  I've wanted this as well.  Perhaps you could have a column in you Excel worksheet with a link to the file location.  The, PLM360 would grad the file and attach it.
nguyentru
Status changed to: Accepted
 We definitely would like to see progress on this.   If PLM360 allows for attachments in the first place, it should also have the ability to upload/ download in bulk.  We want to have control of the files we attach and that also means being able to search for it.
Creating customization  using the REST api is a challenge for the average user I presume.
agreed.
note that some of the comptition (even Windchill!) does bulk imports and linking, so it shouldn't be considered an unusual request.
richard.valdez
has this been implemented? it doesn't seem that it has.
gasevsm
Greetings,
Kindly make use of our ReST API to seed attachments en masse into the tenant. There are no immediate plans to introduce bulk attachment load in next six months. For info on the API take a peek at the following:
- create new attachment. http://help.autodesk.com/view/PLM/ENU/?guid=GUID-F31EF246-A5EA-4892-B188-AA3F11DE4DBB
- checkin/out and delete attachments. http://help.autodesk.com/view/PLM/ENU/?guid=GUID-2A356A1D-F64E-436A-9A2B-7C83D1E70E2B
Hope this helps,
benderk
Thank you for submitting your idea.  The timing isn't quite right for this to be a priority for development consideration.  As such, we will put this on the back-burner to revisit at a later date.  Please continue to comment and add your support.
Sincerely,
Keri Bender | Global GTM Business Strategy Manager
benderk
Thank you for submitting your idea. Have you tried the Modern Interface lately? We request that you review your idea in the context of the Modern interface. If your idea is not addressed, we invite you to create a new Idea in the context of Modern so that it can be addressed accordingly. Sincerely, Keri Bender | Global GTM Business Strategy Manager, Product Lifecycle Management
benderk
Status changed to: Archived
