• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    1 Kudo
    Advanced Print View - Save button
    Status: Implemented
    by Distinguished Contributor Brausmith on ‎09-06-2012 10:57 PM
    Description
    Working through the creation of an Advanced Print View is a tedious process. It's nice to have the Advanced Print View open on one page, and then the actual Print page open in another. Typically this requires a constant refresh of the Print page to see the affects of changed settings on the Advanced Print View.
    Impact
    Currently, on the Advanced Print View when you press the Save button it takes you back to the print views list. Then you need to press Edit for the print view to go back into the view for editing. Then the cycle happens again, ...
    This is very tedious.
    Severity
    Medium
    Solution
    On the Advanced Print View, it would be nice to have an extra button Save & Close. This would save the view and then close back to the views list.
    The existing Save button should be repurposed so that it simply saves the view and leaves the users in the edit mode.
    Status: Implemented
    Comments
    by Employee jared.sund on ‎09-25-2012 10:22 PM
    Status changed to: Accepted
    This should be an easy fix, we'll see if we can get this into one the next few releases.
    by Employee jared.sund on ‎04-08-2013 07:46 AM
    by Distinguished Contributor Brausmith on ‎04-08-2013 10:57 PM
    Nice.
    Big thanks to the PLM team for the quick imporvements which get done.
    IdeaStation Guidelines
    Review guidelines and best practices
    before posting a new idea
    PLM 360 Survey
