Autodesk ObjectARX
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
worldDraw( ) problem
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have a problem with worldDraw(), we can use
AcGiWorldDraw * mode ,
define a solid ,mode->worldDraw(solid) before
but now can not use; the problem is AcGiDrawable no member worldDraw();
i want to find a new function to replace it .anyone kowns
thanks very much
Re: worldDraw( ) problem
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Please post some code that demonstrates the problem. Describe what you think it should do, and what it actually does, to clarify what is not working.
Owen Wengerd
ManuSoft
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you can reply.
AcDb3dPolyline *p3dPoly=new AcDb3dPolyline(AcDb::k3dSimplePoly,points, Adesk::kTrue );
AcDbRegion *pRegion;
AcDbVoidPtrArray regions;
AcDbVoidPtrArray voidPtrArr;
voidPtrArr.append(p3dPoly);
Acad::ErrorStatus es = AcDbRegion::createFromCurves(voidPtrArr, regions);
pRegion = AcDbRegion::cast((AcRxObject*)regions[0]);
AcDbRevolveOptions revolveOptions;
AcDb3dSolid *pSolid = new AcDb3dSolid();
pSolid->createRevolvedSolid( pRegion,startPt1, -vector1, 12*asin(0.5), 0, revolveOptions);
pSolid->worldDraw(mode);
delete pSolid;
when compilethe problem occurs at worldDraw(mode), AcGIdrawable has no member worldDraw(), but in another computer .it can compile and run .i want to know why, and whether there is a new methed to replace it .
thanks
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
i find the problem where it is;
is pSolid->worldDraw(mode);
very thanks .
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I don't understand; did you solve the problem? If so, please describe the solution in case someone else has the same problem.
Owen Wengerd
ManuSoft
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I think what you want to do is:
mode->geometry().draw(pSolid);
this initializes the gi system correctly by calling AcDbEntity::setAttributes(..) then AcDbEntity::worldDraw(..) and finally (if required by worldDraw result) AcDbEntity::viewportDraw().
calling directly pSolid->worldDraw(mode) may result in unexpected behavior (for instance, it may mess up the graphic system cache)
regards
