what is wrong with my code
am trying to close currently opened document using Object ARX wrappers class.
am getting following exception
-> System.Runtime.InteropServices.COMException (0x8021006F): Drawing is busy.
Here is my code.
mApp = (AcadApplication)Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication;
mApp.ActiveDocument.Close(true, mApp.ActiveDocument.Name);
Is any thing wrong with my code.
Ramesh V
i am having the same error. did you figure out how to get around the "drawing is busy" error or has anyone else in vb.net or c# and .net 2005????
I had to bump this long dead post, because I'm having the same problem and all I was able to find was same questions without answers
the only difference is, that I am using VB
(AutoCAD version Civil 2010)
Post in the .NET forum, and include your code because the
crystal ball was sent out to be polished.
problem solved
the issue was, that my program was not running in session context, so the last drawing couldn't be closed
