- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
0. vs2010 and acad2013, 32bit
1. download sdk 2013 at http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=785550
2. download training 2013 and 2014 at http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1911627
(2013 still showed the toolbar, 2014 seemed more up to date with regards to the sdk 2013 project template)
3. create project in vs2010 (manual / based on sdk wizard 2013, 32bit) as per training 2014
4. results:
(a) step01 (manual) - builds but via arx, load in acad: "projectname.arx is incompatible with this version of AutoCAD. AcRxDynamicLinker failed to load ...";
(b) step02 (project wizard) - i fail to have it build without errors (i.e. making the two command names members of the class; tried the solved project files but still couldn't figure it out);
(c) step03 (project wizard) - as step01, i.e. "projectname.arx is incompatible with this version of AutoCAD. AcRxDynamicLinker failed to load ...";
perhaps somebody has followed the training successfully, or made similar experiences etc?
any feedback much appreciated, thanks
