Autodesk ObjectARX
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
how to insert a point on a spline
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I can't find any good method to insert a point on a spline, please see the code below. I want to insert a point on an existing spline, and after insertion ,the shape of the spline shoud not change much.
AcDbObjectId idSpline;
if (!Acad_Selection:
elEnt(idSpline,_T("spline")))
return;
AcDbSplinePointer pSpline(idSpline,AcDb::kForWrite);
if (Acad::eOk != pSpline.openStatus()) return;
ads_point pt;
if (acedGetPoint(NULL,_T("\nclick:"),pt) != RTNORM)
return;
AcGePoint3d pt3d;
pSpline->getClosestPointTo(asPnt3d(pt),pt3d);
double dParam = -1;
pSpline->getParamAtPoint(pt3d,dParam);// here , the value of dParam is not what I want.
acutPrintf(_T("\n%g,round:%d,floor:%d,ceil:%d"),d
pSpline->insertFitPointAt(floor(dParam),pt3d);
Re: how to insert a point on a spline
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
What is your overall goal, and what exactly is the problem with the code you posted?
Owen Wengerd
ManuSoft
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
my purpose is to insert a fit point to the spline. I get get closest point P1 on the spline for the point I click on the screen.
but through the method getParamatPoint, the param I got of P1 has nothing to do with the fit point. I want to use insertFitPointAt. and insertFitPointAt requires the number of fit point. is there an existing method that can return which two fit points P1 is between.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
There is no existing method to do that directly. You did not describe your overall goal, so I can't offer any alternative solutions.
Owen Wengerd
ManuSoft
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
oh, if so , I have to calculate the "param" for each fit point, then compare these params with the insert point and determine which fit point is the right one for "insertFitPointAt".
still,thanks a lot.
