• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk ObjectARX
    Moderator
    Alexander.Rivilis
    Re: how to change the value of user variable of autocad2010
    02-21-2013 02:29 AM in reply to: zhangxinhua789
    Ok. I've tested my code from post 4 and it do it the same you ask me.
    1. Compile and build arx-file with code I've posted.
    2. Start AutoCAD and load arx-file into AutoCAD.
    3. Starting command ADDASSOCVAR and you see how line changed.
    Command: ADDASSOCVAR
    Variable name: user1
    Variable expression: 100
    So before command:
    And after command:
    Пожалуйста не забывайте про Утвердить в качестве решения!Утвердить в качестве решения и Give Kudos!Баллы
    Please remember to Accept Solution!Accept as Solution and Give Kudos!Kudos
    Please use plain text.
    Active Contributor
    02-26-2013 05:28 PM in reply to: zhangxinhua789
    Thank you very much! It's very kind of you.you are my mentor.
    Regards
    Active Contributor
    02-26-2013 07:27 PM in reply to: Alexander.Rivilis
    Hello,experts
      I have a new question,I want to know how to use the Dynamic Blocks in objectarx2010. I define a Dynamic Block in autocad2010,Now I want to insert the Dynamic Block in a dwg-file,can you tell me the code?Thank you very much!
      this is a screenshot of the Dynamic Blocks,I want to insert the Dynamic Block in the position(x=50,y=50),and I want change the three dimensions:
    before command:they are d1=48;d2=96;d3=43
    after  command:they are d1=98;d2=150;d3=70
    I think the class of AcDbDynBlockReference is useful,but I don't know how to use it.Can you help me?
    Active Contributor
    02-26-2013 11:25 PM in reply to: Alexander.Rivilis
    Hello,experts
    I have a new question,I want to know how to use the Dynamic Blocks in objectarx2010. I define a Dynamic Block in autocad2010,Now I want to insert the Dynamic Block in a dwg-file,can you tell me the code,Thank you very much!
    this is a screenshot of the Dynamic Blocks,I want to insert the Dynamic Block in the coordinate position(x=50,y=50),and I want change the three dimensions:
    And I have attached this dwg-file in my post in order to you can test your code with it(I have
    defined the the Dynamic Block,its name is a;you can try to insert it in autocad2010).
