findout dynamic block
Moshe-A
Mentor Mentor
Message 1 of 9
Moshe-A
Is there a way to findout that AcDbBlockTableRecord is dynamic block except of iterating it?
thanks in advance
moshe
Replies (8)
Message 2 of 9
Alexander.Rivilis
static bool AcDbDynBlockReference::isDynamicBlock( AcDbObjectId blockTableRecordId );
 This method help you to identify if block is dynamic or no.
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 3 of 9
Moshe-A
Alexander,
thanx for your reply.
but that not what i'm asking, i what to know if AcDbBlockTableRecord is dynamic?
let's say i have in database some old blocks version in AcDbBlockTable and i want to upgrade them to a new
version which is dynamic. with AcDbDynBlockReference::isDynamicBlock() i have to catch one
block reference and check it...but what if there isn't any insert? should i do a dummy insert to check it?
that's sounds unlogic.
Moshe
Message 4 of 9
Alexander.Rivilis
@Moshe-A wrote:
Alexander,
No. This method is static. That is why you can use it same way:
AcDbObjectId idBTR; // id of BlockTableRecord
if (AcDbDynBlockReference::isDynamicBlock(idBTR)) {
  acutPrintf(_T("\nBlock is dynamic"));
} else {
  acutPrintf(_T("\nBlock is not dynamic"));
Expert Elite Member
Message 5 of 9
Moshe-A
i'm sorry Alex, you are right, my mistake
thank you
Message 6 of 9
Moshe-A
Alexander,
wait...
In order to be able to use ->  AcDbDynBlockReference::isDynamicBlock(AcDbObjectId blockTableRecordId);
first you need to construct AcDbDynBlockReference with AcDbBlockReference object as an argument
AcDbDynBlockReference(AcDbBlockReference* pRef);
AcDbDynBlockReference(AcDbObjectId blockRefId);
so this send me back to start, Am i right?
moshe
Message 7 of 9
Alexander.Rivilis
NO! NO! NO!
Are you know how to call static method of class? OK. Full sample:
static void CheckDynBlock(void)
    ACHAR blockName[512];
    if (acedGetString(TRUE,_T("\nBlock name: "), blockName) == RTNORM) {
        AcDbBlockTableRecordPointer pBTR(blockName, acdbCurDwg(), AcDb::kForRead);
        if (pBTR.openStatus() == Acad::eOk) {
            if (AcDbDynBlockReference::isDynamicBlock(pBTR->objectId())) {
                acutPrintf(_T("\nBlock <%s> is dynamic."), blockName);
            } else {
                acutPrintf(_T("\nBlock <%s> is not dynamic."), blockName);
        } else {
            acutPrintf(_T("\nCan not open block <%s>. Error: <%s>"),
                blockName, acadErrorStatusText(pBTR.openStatus()));
Expert Elite Member
Message 8 of 9
Moshe-A
got it, thank you
Message 9 of 9
Alexander.Rivilis
@Moshe-A wrote:
got it, thank you
And what about Accept solution? Smiley Happy
Expert Elite Member
