• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk ObjectARX
    Distinguished Mentor
    Moshe-A
    Accepted Solution
    findout dynamic block
    180 Views, 8 Replies
    10-02-2012 07:31 AM
    Is there a way to findout that AcDbBlockTableRecord is dynamic block except of iterating it?
    thanks in advance
    moshe
    Please use plain text.
    Moderator
    Alexander.Rivilis
    Re: findout dynamic block
    10-02-2012 02:14 PM in reply to: Moshe-A
    static bool AcDbDynBlockReference::isDynamicBlock( AcDbObjectId blockTableRecordId );
     This method help you to identify if block is dynamic or no.
    Пожалуйста не забывайте про Утвердить в качестве решения!Утвердить в качестве решения и Give Kudos!Баллы
    Please remember to Accept Solution!Accept as Solution and Give Kudos!Kudos
    Moshe-A
    10-02-2012 02:49 PM in reply to: Alexander.Rivilis
    Alexander,
    thanx for your reply.
    but that not what i'm asking, i what to know if AcDbBlockTableRecord is dynamic?
    let's say i have in database some old blocks version in AcDbBlockTable and i want to upgrade them to a new
    version which is dynamic. with AcDbDynBlockReference::isDynamicBlock() i have to catch one
    block reference and check it...but what if there isn't any insert? should i do a dummy insert to check it?
    that's sounds unlogic.
    Moshe
    Moderator
    Alexander.Rivilis
    10-02-2012 02:58 PM in reply to: Moshe-A
    Moshe-A wrote:
    Alexander,
    No. This method is static. That is why you can use it same way:
    AcDbObjectId idBTR; // id of BlockTableRecord
    if (AcDbDynBlockReference::isDynamicBlock(idBTR)) {
      acutPrintf(_T("\nBlock is dynamic"));
    } else {
      acutPrintf(_T("\nBlock is not dynamic"));
    Moshe-A
    10-02-2012 03:08 PM in reply to: Alexander.Rivilis
    i'm sorry Alex, you are right, my mistake
    thank you
    Moshe-A
    10-02-2012 10:52 PM in reply to: Alexander.Rivilis
    Alexander,
    wait...
    In order to be able to use ->  AcDbDynBlockReference::isDynamicBlock(AcDbObjectId blockTableRecordId);
    first you need to construct AcDbDynBlockReference with AcDbBlockReference object as an argument
    AcDbDynBlockReference(AcDbBlockReference* pRef);
    AcDbDynBlockReference(AcDbObjectId blockRefId);
    so this send me back to start, Am i right?
    moshe
    Moderator
    Alexander.Rivilis
    10-03-2012 06:27 AM in reply to: Moshe-A
    NO! NO! NO!
    Are you know how to call static method of class? OK. Full sample:
    static void CheckDynBlock(void)
        ACHAR blockName[512];
        if (acedGetString(TRUE,_T("\nBlock name: "), blockName) == RTNORM) {
            AcDbBlockTableRecordPointer pBTR(blockName, acdbCurDwg(), AcDb::kForRead);
            if (pBTR.openStatus() == Acad::eOk) {
                if (AcDbDynBlockReference::isDynamicBlock(pBTR->objectId())) {
                    acutPrintf(_T("\nBlock <%s> is dynamic."), blockName);
                } else {
                    acutPrintf(_T("\nBlock <%s> is not dynamic."), blockName);
            } else {
                acutPrintf(_T("\nCan not open block <%s>. Error: <%s>"),
                    blockName, acadErrorStatusText(pBTR.openStatus()));
    Moshe-A
    10-03-2012 07:22 AM in reply to: Alexander.Rivilis
    got it, thank you
    Moderator
    Alexander.Rivilis
    10-03-2012 07:24 AM in reply to: Moshe-A
    Moshe-A wrote:
    got it, thank you
    And what about Accept solution? :smileyhappy:
