• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk ObjectARX
    New Member
    custom paper size
    119 Views, 1 Replies
    08-29-2012 11:30 AM
    hello together,
    the topic „custom paper size“ has already mentioned in several threats,
    but unfortunetely there are no answers which give me help.
    is it possible to add a „custom papersize“?
    Would this be a solution maybe?
    - to edit the pc3 file – are there any interfaces or is a word proseccing of the file possible?
    - or does the „AcPlPlotInfoValidator“ can be used where is also a function „isCustomPossible“
      or "AcPlPlotConfig::makeCustomMediaFromSizeDesc"?
    - there is also an assistend  where you can add a plotter (Pc3 file)
       which is in the same folder like the pc3 files – does this maybe work out?
    i am looking forward to get an official response to this problem and also every suggestion which can be helpful.
    Thank you all...
    Please use plain text.
    ADN Support Specialist
    Balaji_Ram
    Re: custom paper size
    09-04-2012 05:37 AM in reply to: _micha
    Sorry, there is no API to create a custom paper size.
    Also the PC3 file is a compressed file similar to a .CUIX and cannot be parsed as an XML.
    A way to use custom paper size is to use the "Plotter Configuration Editor" (launched by double clicking a pc3 file) to create a new pc3 file with the custom paper sizes.
    This pc3 can then be deployed in the plotter folder.
    Balaji
    Developer Technical Services
    Autodesk Developer Network
