• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk ObjectARX
    vianova.th
    choosing method to getSection
    122 Views, 2 Replies
    09-05-2012 09:13 PM
    I would like to get section objects of solid/surface by vertical plane , I found 2 groups of method which are (AcDb3dSolid::getSection and AcDbSurface::createSectionObjects) and AcDbSection::generateSectionGeometry.
    They seem to do similar things.. pls advise how to choose, any performace issue or which suitable for which task?
    Thanks in advance..
    Please use plain text.
    ADN Support Specialist
    Re: choosing method to getSection
    09-10-2012 04:15 PM in reply to: vianova.th
    Have you seen the SectionPlane sample in the ObjectARX 2009 SDK... It shows how to do what you want, I think.
    Fenton Webb
    Developer Technical Services
    Autodesk Developer Network
    Moderator
    Alexander.Rivilis
    09-10-2012 09:32 PM in reply to: fenton.webb
    Previous versions of ObjectARX SDK
    Пожалуйста не забывайте про Утвердить в качестве решения!Утвердить в качестве решения и Give Kudos!Баллы
    Please remember to Accept Solution!Accept as Solution and Give Kudos!Kudos
