• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk ObjectARX
    Distinguished Mentor
    Moshe-A
    attributes are placed in 0,0 position
    126 Views, 9 Replies
    11-07-2012 10:28 PM
    Hi Guys,
    In my application i have three block symbols contains some attributes. the current task i'm working on
    is converting an old version of these blocks (the new version also are dynamic blocks)
    let's say i have a host database that has a xref in and the xref contains the old blocks.
    i scan the current database (AcDbBlockTableRecord) for that xref, open it and scan the xref database (AcDbBlockTableRecord) for those blocks it turn i find each block make an update insert (insert= from outside database) and replace each AcDbBlockReference. this all process work fine except the attributes at first are places
    on the 0,0 position. after audit the xref and regen it, the attributes are restores in place were they should be.
    would like to mention that i did not encounter this problem when i insert the blocks in the current database
    or even replacing the symbols inside a standard block.
    Any one knows what is my problem?
    thanks in advance
    moshe
    Please use plain text.
    Moshe-A
    Re: attributes are placed in 0,0 position
    11-08-2012 04:10 AM in reply to: Moshe-A
    foregot to mention that audit results no errors
    11-08-2012 07:20 AM in reply to: Moshe-A
    Have you tried setting the database current before adding the attributes?
    Owen Wengerd
    ManuSoft
    Moshe-A
    11-08-2012 10:27 AM in reply to: owenwengerd
    Hi Owen,
    NO
    What do you mean by that? to set the Xref database current?
    can i do that without closing the host database?
    thanx
    Moshe
    11-08-2012 06:32 PM in reply to: Moshe-A
    Yes, and yes.
    Owen Wengerd
    ManuSoft
    Moshe-A
    11-09-2012 12:34 AM in reply to: owenwengerd
    tried it and it still doesn't work, hope i use it good (cause i have never used AcApDocumentManager)
    here's what i did
    ACHAR XrefFile[32= = _T("xref.dwg");
    AcDbDatabase *pXref = NULL;
    // allocating memory
    pXref = new AcDbDatabase(Adesk::kFalse);
    pXref->readDwgFile(XrefFile);		{
    // switch databases
    acDocManager->setCurDocument(acDocManager->document(pXref));
    replace_old_symbols(pXref); // real work
    // restore current database
    acDocManager->setCurDocument(acDocManager->document(pCurDwg));
    pXref->saveAs(XrefFile);
    delete pXref; // dispose memory
    i would like to understand why is this happends - do you have explanation?
    Moshe
    Moshe-A
    11-09-2012 02:19 AM in reply to: Moshe-A
    Owen,
    here's a simple test is did:
    i draw a rectangle on the current database (with RECTANGLE command)
    disable the call to restore the current database
    // acDocManager->setCurDocument(acDocManager->document(pCurDwg));
    then build & load & run my application again
    then i tried to select the rectangle and i did successed
    i thought if the xref database is current i won't be able to select objects in pCurDwg
    is this means that the call
    is not acutally done?
    11-09-2012 07:27 AM in reply to: Moshe-A
    Try instead AcDbHostApplicationServices::setWorkingDatabase().
    Owen Wengerd
    ManuSoft
    Moshe-A
    11-09-2012 07:49 AM in reply to: owenwengerd
    Hallelujah!
    it's working fine
    thank you very much owen
    i'm sure you have explanation to this and i understand it's related to display and graphics
    but why does this happends only to attributes?
    Moshe
    11-09-2012 08:54 AM in reply to: Moshe-A
    I can only speculate that calculating text position after an alignment change requires information from the working database, and that the process is intentionally skipped or fails for some reason when the working database is different from the database of the target text object.
    Owen Wengerd
    ManuSoft
