Please help me with right handed MutliLeaders
I have written a function that creates AcDbMLeader and it produces perfect leaders. I just can' make the leader lines start on the right hand side of the mtext.
I have used the set functions in different combinations but nothing seems to work.
Does anyone have any ideas as to why this might be?
Many thanks
Balaji_Ram
Hello Kenneth,
Have you tried using the "AcDbMLeader::setDoglegDirection" ?
This method turns the short line based on the direction vector provided to it.
If this does not help, can you please post a simple example to demonstrate the problem ?
Balaji
Developer Technical Services
Autodesk Developer Network
Hi Balaji,
Thank you for the suggestion I will try that out and let you know if it fixes my problem.
I will attach my code if still I can't get it to work.
Thanks again,
Ken
