Please advise me that getting any "Tins" from "Face" or "Surface" ?
Since, I  can get any sample points by using "getSamplePoints(..)" method when working on "AcGeCurve3d".
I'd like to know how I can get any "Tins" from "Face" or "Surface", while I'm working on  "AcBrFace" or "AcGeSurface".
Please advise me.
Yours sincerely.
Balaji_Ram
Hi Vianova,
Can you clarify what you mean by getting "Tins" ? You may attach some screenshot if that can help.
Even if I cant, it will help other experts viewing your question to answer it.
Balaji
Developer Technical Services
Autodesk Developer Network
Let me try to ask again here.
From AcGeCurve3d, I could get representative string line (without curve) within accuracy I give to function getSamplePoints().
With the same idea but for AcGeSurface or AcBrFace (or any curve surface).. can I get representative Triangle faces (without curve) within accuracy from any func or method ?
Please advise me.
Yours sincerely.
Balaji_Ram
Hi Vianova,
Here is a sample code snippet that might help. The "evalPoint" method of the AcGeSurface might be the one you are looking for.
		AcDbSurface *pSurface = NULL;
		Acad::ErrorStatus es = acdbOpenAcDbEntity((AcDbEntity *&)pSurface, surfaceOid, AcDb::kForRead);
		if(es == Acad::eOk)
			AcBr::ErrorStatus es;
			AcDbBody body;
			body.setBody(pSurface->body ());
			AcBrBrep brep;
			if((es = brep.set(body)) != AcBr::eOk)
				return;
			AcBrBrepFaceTraverser faceTrav;
			if((es = faceTrav.setBrep(brep)) != AcBr::eOk)
				return;
			for(faceTrav.restart();!faceTrav.done();faceTrav.next())
				AcBrFace face;
				if(faceTrav.getFace(face) != AcBr::eOk)
					continue;
				AcGeSurface* pSurfaceGeometry = NULL;
				if((es = face.getSurface(pSurfaceGeometry)) != AcBr::eOk)
					return;
				AcGePoint2d param(pSurfaceGeometry->paramOf(AcGePoint3d(2.5, 2.5, 0.0)));
				AcGePoint3d pt(pSurfaceGeometry->evalPoint(param));
				acutPrintf(ACRX_T("(%lf, %lf, %lf)"), pt.x, pt.y, pt.z);
				delete pSurfaceGeometry;
		pSurface->close();
Balaji
