• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk ObjectARX
    Distinguished Contributor
    ObjectARX Wizard 2012 on VS 2010
    343 Views, 2 Replies
    09-06-2012 11:12 AM
    I'm getting an error during the creation of a new C++ project in VS 2010 using the ARX Wizard 2012
    --------------------------- Microsoft Visual Studio ---------------------------
    Specified argument was out of the range of valid values.
    Parameter name: value
    --------------------------- OK   ---------------------------
    Then the project is not built. Has anyone else seen this?
    Please use plain text.
    ADN Support Specialist
    Virupaksha.aithal
    Re: ObjectARX Wizard 2012 on VS 2010
    09-10-2012 11:19 PM in reply to: odoshi
    Hi
    Are you creating mixed managed project? If yes, then try below step
    Edit the following file like below
    C:\Program Files (x86)\Autodesk\ObjectARX Wizards for AutoCAD 2012\ArxAppWiz\Scripts\1033\default.js
    Line #122
    Change
    config.ManagedExtensions =bDotNetModule ;
    into
    config.ManagedExtensions =(bDotNetModule == 'True') ;
    Virupaksha Aithal KM
    Developer Technical Services
    Autodesk Developer Network
    09-11-2012 06:01 PM in reply to: Virupaksha.aithal
    Yes, it was a mixed managed project. That fixed it.
    Thank you!
