Object Properties Manager Customization
I'm attempting to add SQL data links to the Object Properties Manager as well as the "pop-up" hover window. I was notified of the SimpleDynProps example in ObjectARX, but as it turns out the SimpleDynProps is not available in ObjectARX 2011. I rather new to AutoCAD customization so any help would be greatly appreciated. I've seen this done using the 2009 version but I only have the 2011 and 2012 versions.
augusto.goncalves
The API still valid, so should work, you just need to compile with VS2008 (for Acad 2010/11/12) instead VS2005 (for Acad 2007/8/9), of course using the proper ARX SDK include files.
Augusto Goncalves
Autodesk Developer Network
Augusto Goncalves
Twitter @augustomaia
