• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk ObjectARX
    Active Member
    janossycs
    Accepted Solution
    LISP Global variable -> ObjectARX 2013
    240 Views, 4 Replies
    11-23-2012 07:41 AM
    another question: how can I get global string variable for a process then save it? I want to put the LISP global string variable *CI_Ido* into str string variable using the getsym function. I have an rstring, and I want to convert to a string:
    int rc;
    struct resbuf *rb;
    string longT,
    str;
    rc = ads_getsym(_T("*CI_Ido*"), &rb); if (rc == RTNORM && rb->restype == RTSTR) { str = rb->resval.rstring; /* this my question */ if (str.length()==17) { longT = str.substr(14,4) + "." + str.substr(1,4); rb = ads_buildlist(RTSTR, longT, 0); rc = ads_putsym(_T("*CI_Valt*"), rb); ads_rett(); } else { ads_retnil(); } } else { ads_retnil(); } ads_relrb(rb);
     many thanks,
    Csaba
    Please use plain text.
    Re: LISP Global variable -> ObjectARX 2013
    11-23-2012 10:53 AM in reply to: janossycs
    What exactly is the problem? Build error? Runtime error? Crash?
    Owen Wengerd
    ManuSoft
    Moderator
    Alexander.Rivilis
    11-24-2012 10:06 AM in reply to: janossycs
    Not string but wstring
    Пожалуйста не забывайте про Утвердить в качестве решения!Утвердить в качестве решения и Give Kudos!Баллы
    Please remember to Accept Solution!Accept as Solution and Give Kudos!Kudos
    11-24-2012 02:53 PM in reply to: janossycs
    TRY MY SOLUTION
    [code]
    ACHAR *
    /*FCN*/lspfn_setq(ACHAR *variabile,const ACHAR *value)
    { int rc;
      if (variabile==NULL)
              ads_retnil();
             return(variabile);
      struct resbuf *rb;
      rb = ads_buildlist(RTSTR, value, NULL);
      rb.rbnext=nil;
      rc = ads_putsym(variabile, rb);
      if (RTNORM==ads_retstr(rb->resval.rstring))
        { ads_relrb(rb);
          ads_retstr(value);
          return(value);
      ads_relrb(rb);
      ads_retnil();
      return(NULL);
    int
    /*FCN*/test()
    {   int rc;
        struct resbuf *rb;
        ACHAR str2[12];
        if (rc!=RTNORM)
              { ads_retnil(); return(rc);};
        iF (rb==NULL)
              { ads_retnil();
                return(RTERROR);
         if (rb->restype != RTSTR)
              { ads_retnil();
                return(RTCAN);
         if (rb->resval.rstring==NULL)
              { ads_retnil();
                return(RTREJ);
         rc=_tcslen(rb->resval.rstring);
         if (rc!=17)
              { ads_retnil();
                return(RTFAIL);
                       // here maximum speed  and codesize it si little
           str2[0]=rb->resval.rstring[14];
           str2[1]=rb->resval.rstring[15];
           str2[2]=rb->resval.rstring[16];
           str2[3]=rb->resval.rstring[17];
           str2[4]=_T('.');  // here maximum  speed  and codesize it si little
           str2[5]=rb->resval.rstring[01];
           str2[6]=rb->resval.rstring[02];
           str2[7]=rb->resval.rstring[03];
           str2[8]=rb->resval.rstring[05];
           str2[9]=_T('\0');
           str2[10]=_T('\0');
           str2[11]=_T('\0');
          lspfn_setq(_T("*CI_Valt*"), str2);
          ads_rett();
          ads_relrb(rb);
          return(RTNORM);
    [/code]
    Active Member
    janossycs
    11-26-2012 01:47 AM in reply to: diagodose2009
    The error was: no operator "=" matches this operand.
    The wstring type has resolved it, and this one is the easyest way for me, but I will test the 2nd solution and build in.
    Maybe you ask why I need ObjectARX for this process, why not enough LISP, because it's a test and I need to compare the results of LISP and ObjectARX.
    Thanks for everyone the answer!
