Is realy object modified?
How to chek is object modified, because objectModified() event occurs when
object was opened, but it may be still the same 😞 I need only thows objects
witch let say coordinates changed (not just was opened and closed). Any
idea?
As far as i know, there's no way to directly find out if an object was
ACTUALLY modified. I've been struggling with this fact for a long time. In
my particular case, however, all i need to know is whether the object has
been moved or not. For that i store a point in my custom object -
m_pntLastPosition. Everytime the objectModified( ) function gets fired, i
check that variable. If my NEW point doesn't match the LAST one, then i
know the object has been moved. What's the specific property that you need
to be aware of?
Another possible solution that i considered was to override the functions in
my custom object that correspond to the properties i'm concerned about.
What i mean by that is that if i need to know if an object gets moved, i can
override the TransfromBy() function, and toggle a m_bWasModified boolean.
Then, when objectModified gets called, i can identify that some sort of
significant change was made.
"Mindaugas Bliudzius" wrote in message
news:[email protected]...
> Hi,
objects
> idea?
Hi, thank's for reply,
The problem is that i need to retriangulate surface when point was modified
or deleted. It take a bit of time so i don't want regenerate surface if
someone just opened and closed that point. At first i removed kForWrite
(because this call event) from my program where i'm cheking objects and only
if i realy need to change objetc i used upgeradeOpen(). But still some other
program can do that 😞
The main reason why your replay is good, that now i know that there is no
straight way to do that 🙂 It is good to know that when you doing something
that there is no easier way 🙂 And thank's one more time for your
suggestions. I'll try to use them.
"Justavian" wrote in message
In
need
> to be aware of?
in
can
> > Hi,
when
> objects
> > idea?
Mindaugas,
modified
Don't forget the undo function!
You might want to investigate overriding the AcDbDatabaseReactor reactor;
class dBaseReactor : public AcDbDatabaseReactor
public:
virtual void objectUnAppended(const AcDbDatabase* dwg, const
AcDbObject* dbObj);
virtual void objectAppended(const AcDbDatabase *pDwg, const
AcDbObject *pDbObj);
virtual void objectModified(const AcDbDatabase *pDwg, const
virtual void objectErased(const AcDbDatabase *pDwg, const
AcDbObject *pDbObj, Adesk::Boolean erased);
virtual void objectOpenedForModify(const AcDbDatabase* dwg, const
AcDbObject* dbObj);
and check in theses functions for your object!
Regards Gary
www.drcauto.com
modified
only
other
something
> In
has
i
> need
> > to be aware of?
functions
> in
> can
boolean.
> > > Hi,
> when
> > objects
Any
> > > idea?
