• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk ObjectARX
    *Van Ausdall, Steve
    IPropertyManager example
    152 Views, 6 Replies
    12-19-2001 08:52 AM
    I've been looking around for examples of using the IPropertyManager
    to retrieve custom properties from entities, but can't seem to
    find any. Can anyone help?
    Steve
    Please use plain text.
    *Schlingheider, J.
    Re: IPropertyManager example
    12-27-2001 04:29 PM in reply to: *Van Ausdall, Steve
    Hi Steve,
    here's a sample for the creation of Properties with the help of
    IPropertyManager. The property manager acts as a container for your dynamic
    properties and handles them.
    You can create your dynamic properties with the objarx wizard, which creates
    a propertyadmin, which you don't need explicitly. What I did was to use the
    wizard to get proper properties classes, delete the admin and handle the
    dynprops within my custom objects like in the sample. I encountered a
    problem of Acad by trying to use dynamic props for custom classes directly.
    Here you have to use custom object COM wrappers otherwise acopm will get
    confused and mixes up the properties of different classes.
    Hope to help
    Joerg
    Sample code:
    long CMyClass::setProps()
    CComPtr mm_pPropMan;
    XLinieProperty *mm_newProp = NULL; //My dynamic property
    long mm_ct = -1;
    mm_pPropMan = GET_OPMPROPERTY_MANAGER(this->isA());
    if (mm_pPropMan != NULL)
    mm_pPropMan->GetDynamicPropertyCount(&mm_ct);
    //create only if not already done...
    if (0 != mm_ct) return mm_ct;
    //Create a custom dynamic property
    if SUCCEEDED( XLinieProperty::CreateInstance( &mm_newProp ))
    mm_newProp->AddRef();
    //Fill up the attributes of the dynamic property (depends on your
    implementation of your dynprop)
    mm_newProp->SetCategory("Line-Props");
    mm_newProp->SetCategoryId( 0 );
    mm_newProp->SetCaption("Name");
    mm_newProp->setNumber(-1);
    mm_newProp->SetEditable(true);
    mm_newProp->setType(VT_BSTR);
    //add it to the propman
    _com_util::CheckError(mm_pPropMan->AddProperty( mm_newProp ));
    mm_ct++;
    return mm_ct;
    Steve Van Ausdall schrieb in im Newsbeitrag:
    51994ABFC0E0D3976839D08732916C16@in.WebX.maYIadrTaRb...
    > Hi,
    > Thanks,
    > Steve
    *Van Ausdall, Steve
    Re:
    12-31-2001 09:22 AM in reply to: *Van Ausdall, Steve
    Thanks, Joerg!
    I'm actually trying to get properties from entities that someone else wrote.
    The property I want does show up in the property panel. Is there some other
    way to get values to appear there? Could you see if I'm doing something
    stupid? I have the following so far - but mm_ct is always set to 0.
    #include
    AcDbEntity *pEnt;
    AcDbObjectId oObjId;
    IPropertyManager *mm_pPropMan;
    acdbOpenObject(pEnt, oObjId, AcDb::kForRead);
    mm_pPropMan = GET_OPMPROPERTY_MANAGER(pEnt->isA());
    Thanks again,
    Steve
    "J. Schlingheider" wrote in message
    news:smileyvery-happy:5A247625F8C842C878B951F458479BD@in.WebX.maYIadrTaRb...
    > Hi Steve,
    dynamic
    creates
    the
    directly.
    > Hope to help
    > Joerg
    > Sample code:
    > long mm_ct = -1;
    > mm_ct++;
    > return mm_ct;
    > > Hi,
    > > Thanks,
    > > Steve
    *Schlingheider, J.
    Re:
    01-01-2002 05:04 PM in reply to: *Van Ausdall, Steve
    No, its's perfectly straight! mm_ct=0 means that there are none dynamic
    props! But remember, not all props shown in the props dialog are dynamic
    props. I suppose that those props shown are static properties, which come
    from the COM-object wrapper. If you have a look at the typelib of your dbx,
    and look out for the interface of the custom entity, then you'll probably
    see the props (propput,propget) you see in your props dialog, Those
    properties are managed by acopm directly. The way the values you enter are
    assigned to the entity depend on the implemetation within the COM-coclass.
    To change that won't be very easy, one way could be to create a new entity
    which inherits from the existent one, but therefore you'd have to have the
    header files. Another way would be to implement the com-interface in another
    coclass, and try to make acopm use your coclass when accessing the entity
    (by using the same GUID), but in that case you also have to know something
    about the custom entity... so not an easy thing to do.
    Regards, Joerg
    wrote.
    other
    > #include
    > AcDbEntity *pEnt;
    > Thanks again,
    > Steve
    > > Hi Steve,
    > dynamic
    > creates
    > the
    > directly.
    > > Hope to help
    > > Joerg
    > > Sample code:
    property
    > > long mm_ct = -1;
    your
    > > mm_ct++;
    > > return mm_ct;
    > > > Hi,
    > > > Thanks,
    > > > Steve
    *Van Ausdall, Steve
    Re:
    01-02-2002 02:46 AM in reply to: *Van Ausdall, Steve
    Happy New Year!
    Thanks for your help on this - I really appreciate it.
    I don't want to change anything or create new entities. All I want to do is
    read the properties of objects that I don't have the source code for.
    (Like the property window reads them) I don't even know if there is
    a dbx... Is there an easy way to simply read them? Do you have code?
    Would it involve QueryInterface? Is that an MFC thing?
    Thanks again!
    Steve
    news:99E318FF853D44B376967FA11579F4E2@in.WebX.maYIadrTaRb...
    dbx,
    another
    > Regards, Joerg
    > wrote.
    > other
    > > #include
    > > AcDbEntity *pEnt;
    > > Thanks again,
    > > Steve
    > > > Hi Steve,
    > > dynamic
    > > creates
    use
    > > the
    the
    > > directly.
    get
    > > > Hope to help
    > > > Joerg
    > > > Sample code:
    > property
    > > > long mm_ct = -1;
    > your
    > > > mm_ct++;
    > > > return mm_ct;
    > > > > Hi,
    > > > > Thanks,
    > > > > Steve
    *Schlingheider, J.
    Re:
    01-02-2002 07:00 PM in reply to: *Van Ausdall, Steve
    Hi Steve,
    happy new year to you as well!!
    From which point do you want to read the properties? From a selected object,
    when iterating through the database, from VB, ....? If you want to get
    properties via the acopm mechanism you would have to use COM to achieve that. If
    you have your object opened via the IAcadEntity-Interface, you have to use
    QueryInterface in order to get the props of the custom object, you are quite
    right here. Unfortunately I have no code for that problem ready at hand, but
    someone else might have.
    Joerg
    Steve Van Ausdall schrieb:
    > Happy New Year!
    > Thanks again!
    > Steve
    > dbx,
    > another
    > > Regards, Joerg
    > > wrote.
    > > other
    > > > #include
    > > > AcDbEntity *pEnt;
    > > > Thanks again,
    > > > Steve
    > > > > Hi Steve,
    > > > dynamic
    > > > creates
    > use
    > > > the
    > the
    > > > directly.
    > get
    > > > > Hope to help
    > > > > Joerg
    > > > > Sample code:
    > > property
    > > > > long mm_ct = -1;
    > > your
    > > > > mm_ct++;
    > > > > return mm_ct;
    > > > > > Hi,
    > > > > > Thanks,
    > > > > > Steve
    *Van Ausdall, Steve
    Re:
    01-04-2002 02:20 AM in reply to: *Van Ausdall, Steve
    I want to read them while iterating through the database, in C++ (ARX) -
    Thanks again for the help! - Steve
    news:3C3439DC.FD2E61D8@web.de...
    > Hi Steve,
    object,
    that. If
    quite
    but
    > Regards,
    > Joerg
    > > Happy New Year!
    is
    > > Thanks again!
    > > Steve
    dynamic
    dynamic
    come
    > > dbx,
    probably
    are
    COM-coclass.
    entity
    the
    > > another
    entity
    something
    > > > Regards, Joerg
    else
    > > > wrote.
    some
    > > > other
    something
    > > > > #include
    > > > > AcDbEntity *pEnt;
    > > > > Thanks again,
    > > > > Steve
    > > > > > Hi Steve,
    your
    > > > > dynamic
    which
    > > > > creates
    to
    > > use
    > > > > the
    handle
    > > the
    encountered a
    > > > > directly.
    will
    > > get
    > > > > > Hope to help
    > > > > > Joerg
    > > > > > Sample code:
    > > > property
    > > > > > long mm_ct = -1;
    on
    > > > your
    mm_newProp ));
    > > > > > mm_ct++;
    > > > > > return mm_ct;
    Newsbeitrag:
    > > > > > > Hi,
    IPropertyManager
    > > > > > > Thanks,
    > > > > > > Steve
