• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk ObjectARX
    Active Member
    How to load a Managed dll from an arx file?
    246 Views, 5 Replies
    05-03-2012 11:33 PM
    Greetings,
    Recently I had to add some features available only in .NET, to the project I developed using ObjectArx. I created a Managed dll using C#, and I want to load that dll when my main arx dll is loaded. I do not want to demand-load that dll by adding some registry keys.
    As I found the command of "acrxDynamicLinker->loadModule()" does not work for managed dlls. I am wondering if there is another command or method to load a managed dll from inside an arx file.
    With thanks in advance.
    Massoud
    Please use plain text.
    Moderator
    Alexander.Rivilis
    Re: How to load a Managed dll from an arx file?
    05-04-2012 12:44 AM in reply to: massoudshakeri
    1) LoadLibrary()
    2) Also acdbmgd.lib export function LoadManagedDll:
    enum Acad::ErrorStatus __stdcall LoadManagedDll(ACHAR const *path);
    Sample:
    static int ads_netload(void)
      struct resbuf *pArgs = acedGetArgs () ;
      acedRetNil();
      if (pArgs && pArgs->restype == RTSTR) {
      Acad::ErrorStatus es = LoadManagedDll(pArgs->resval.rstring);
      if (es != Acad::eOk) {
         acutPrintf(_T("\nLoadManagedDll(\"%s\")=%s"),
            pArgs->resval.rstring,acadErrorStatusText(es));
      } else
        acedRetStr(pArgs->resval.rstring);
      return (RSRSLT) ;
    Пожалуйста не забывайте про Утвердить в качестве решения!Утвердить в качестве решения и Give Kudos!Баллы
    Please remember to Accept Solution!Accept as Solution and Give Kudos!Kudos
    Active Member
    05-05-2012 11:21 AM in reply to: massoudshakeri
    Thanks for the response. But none of these methods work.
    I need somehow make AutoCAD to load that managed DLL, in the same way acrxDynamicLinker->loadModule works. I do not think LoadLibrary() can do this.
    The second method did not work either.
    Moderator
    Alexander.Rivilis
    05-05-2012 12:40 PM in reply to: massoudshakeri
    Try again. I've attached solution which was tested with AutoCAD 2012. It export command MyNetLoad which is analog of NETLOAD command and lisp function (netload <path_to_managed_dll>)
    Active Member
    05-07-2012 10:31 AM in reply to: massoudshakeri
    Hi Alexander,
    Thank you very much.
    It worked for me.
    Best Regards
    Massoud
    Moderator
    Alexander.Rivilis
    05-07-2012 10:36 AM in reply to: massoudshakeri
    It worked for me.
    What about Accept Solution?
