• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk ObjectARX
    Valued Contributor
    maisoui
    How to define a help call to a URL (website)?
    226 Views, 3 Replies
    02-25-2013 02:50 AM
    I'd like to define a help call for all my commands to my online documentation.In other words, I don't use CHM files, and I'd like to know how use API function acedSetFunHelp with a link to a website and not a CHM?
    I also raises the question whether one function will also define the behavior of F1 button in the ribbon?
    Jonathan
    Please use plain text.
    ADN Support Specialist
    Re: How to define a help call to a URL (website)?
    02-28-2013 09:40 AM in reply to: maisoui
    If I remember correctly, calling a Webpage directly is something like this:
    acedSetFunHelp(_T("MyCOMMAND"),_T(http://mywebsite.com/MyCommandHelp.htm),_T(""), 0) or
    Calling a Webpage directly, with an HTML anchor
    acedSetFunHelp(_T("MyCOMMAND"),_T(http://mywebsite.com/MyProductPage.htm),_T("#MyCommandTopic"), 0) or
    Fenton Webb
    Developer Technical Services
    Autodesk Developer Network
    Valued Contributor
    maisoui
    02-28-2013 10:55 PM in reply to: fenton.webb
    Thank you for your interesting answer. I tested with a URL like this : http://www.mywebsite.com/mycommand/mysection and it didn't work. It seems that if the URL ends with .htm, it works. Do you have more details about that?
    Another question: Do you know how to tell AutoCAD to use the default browser and not IE?
    Jonathan
    04-08-2013 03:09 PM in reply to: maisoui
    I believe that's a Windows registry entry, not an AutoCAD one...Basically setting the default browser... Google will help with this one for you.
    Fenton Webb
