• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk ObjectARX
    Active Member
    How to ask for a password on the command line of AutoCAD 2013 using ObjectARX?
    192 Views, 4 Replies
    10-06-2012 12:35 AM
    How can I ask for a password, replacing each keystroke with a generic character, on the command line of AutoCAD 2013 using ObjectARX?
    Thanks in advance.
    Please use plain text.
    Moderator
    Alexander.Rivilis
    Re: How to ask for a password on the command line of AutoCAD 2013 using ObjectAR
    10-06-2012 02:58 AM in reply to: JoseVicario
    Try this: http://adndevblog.typepad.com/autocad/2012/06/asking-for-a-password-on-the-command-line-of-autocad-u...
    Пожалуйста не забывайте про Утвердить в качестве решения!Утвердить в качестве решения и Give Kudos!Баллы
    Please remember to Accept Solution!Accept as Solution and Give Kudos!Kudos
    Active Member
    10-06-2012 05:34 AM in reply to: Alexander.Rivilis
    Thanks Alexander, but the solution in adndevblog fails in AutoCAD 2013. Look the comment by Thierry Prince below the solution.
    ADN Support Specialist
    Balaji_Ram
    10-13-2012 09:36 AM in reply to: JoseVicario
    Hi Jose,
    Using hooks is a hack that is not generally advisable to use. If you have the option, switch over to a UI to take that input which you are trying to mask. That way you will not need to use hooks.
    However if you still need to go this route, then here is a code snippet based on the low level keyboard hooks. Hope this helps. I havent tested it very extensively but seems to work in general using AutoCAD 2013.
    Here is the sample code :
    static ACHAR password[133];
    static int pwdLen;
    static HHOOK hKeyboardHook;
    // - AdskMyTest1.MyCommand1 command (do not rename)
    static void AdskTestCommand(void)
    	ACHAR pwd[133];
    	adskGetPassword(1, ACRX_T("Password please ?"), pwd);
    static int adskGetPassword(int cronly,ACHAR* prompt,ACHAR* result)
    	pwdLen = 0;
    	password[pwdLen]='\0';
    	HINSTANCE hInstance = GetModuleHandle(NULL);
    	if (!hInstance)
    		return 1;
    	hKeyboardHook = SetWindowsHookEx (
    										WH_KEYBOARD_LL,
    										(HOOKPROC) KeyboardEvent,
    										hInstance,
    										NULL
    	ACHAR tempResult[133];
    	int ret = acedGetString(cronly, prompt, tempResult);
    	UnhookWindowsHookEx(hKeyboardHook);
    	if(ret != RTNORM)
    		acutPrintf(ACRX_T("\nCancelled."));
    	else
    		password[++pwdLen] = '\0';
    		acutPrintf(password);
    	wcscpy(result, password);
    	return ret;
    static LRESULT CALLBACK KeyboardEvent (int nCode, WPARAM wParam, LPARAM lParam)
    	if ((nCode == HC_ACTION) &&
    	((wParam == WM_SYSKEYDOWN) ||
    	(wParam == WM_KEYDOWN)))
    		KBDLLHOOKSTRUCT hooked_key = *((KBDLLHOOKSTRUCT*)lParam);
    		DWORD dwMsg = 1;
    		dwMsg += hooked_key.scanCode << 16;
    		dwMsg += hooked_key.flags << 24;
    		int key = hs.vkCode;
    		if ((key >= 'A' && key <= 'Z')  || (key >= '0' && key <= '9'))
    			GetKeyNameText(dwMsg, &password[pwdLen], 0xFF) + 1;
    			keybd_event(VK_MULTIPLY, hooked_key.scanCode, hooked_key.flags, 0);
    			return 1;
    		else if(hooked_key.vkCode == VK_BACK)
    			password[--pwdLen] = '\0';
    	return CallNextHookEx(hKeyboardHook, nCode,wParam,lParam);
    Balaji
    Developer Technical Services
    Autodesk Developer Network
    Active Member
    10-13-2012 11:05 AM in reply to: Balaji_Ram
    Thanks Balaji for your reply. The code works well with some corrections:
    The line
    must be
    int key = hooked_key.vkCode;
    and the line
    must be
    GetKeyNameText(dwMsg, &password[pwdLen], 0xFF);
