• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk ObjectARX
    Valued Contributor
    maisoui
    Accepted Solution
    How replicate PLINE grip menu on my custom entity?
    224 Views, 4 Replies
    02-04-2013 11:41 PM
    I'd like to replicate the PLINE grip menu on my custom entity : when grip is hovered, a menu is displayed (actions = Stretch Vertex, Add Vertex, Remove Vertex).
    For now, I can display a context menu by:
    1. creating a AcDbGripData (in subMoveGripPointsAt method)
    2. Specifying a custom GripOperation (function ptr) for hover
    3. Creating a CMenu in my custom GripOperation function
    4. Displaying my menu like this :
      BOOL result = pPopup->TrackPopupMenu(TPM_LEFTALIGN | TPM_RIGHTBUTTON | TPM_NONOTIFY | TPM_RETURNCMD, p.x + 15, p.y + 20, AfxGetMainWnd());
      (where p is a POINT representing the current cursor location)
    I don't know if this is the right way because the point of the grip is blue (as if it was warm), while for the PLINE it becomes orange (see the image above).
    And I like to know how to begin move grip process? The PLINE menu launches the command GRIP_STRETCH. I tried to use the same command but I was unable to execute it with:
    acedCommand(RTSTR, _T("_.grip_stretch"), RTENAME, pickSet, RTNONE);
    Maybe someone can provide an example? All suggestions are welcomed.
    Jonathan
    Please use plain text.
    ADN Support Specialist
    Re: How replicate PLINE grip menu on my custom entity?
    02-11-2013 05:50 PM in reply to: maisoui
    Check out the class AcDbMultiModesGripPE class in dbMultiModesGrip.h in the ObjectARX SDK
    Fenton Webb
    Developer Technical Services
    Autodesk Developer Network
    Valued Contributor
    maisoui
    02-12-2013 12:44 AM in reply to: fenton.webb
    Thank you for your answer. It could be a good solution, but I'm using OARX 2010 and I guess AcDbMultiModesGripPE appeared in OARX 2012 or 2013. Is there another solution or it's only a new feature of next OARX?
    Balaji_Ram
    02-14-2013 07:05 AM in reply to: maisoui
    The API for multi-functional grips was introduced in ObjectARX 2012 although AutoCAD had it as a feature in 2011.
    Sorry, there is no way to get it using 2010 SDK.
    Balaji
    Valued Contributor
    maisoui
    02-14-2013 07:07 AM in reply to: Balaji_Ram
    Ok. Thank you for your anwser. I was able to reproduce this feature with a little time and perseverance.
    Jonathan
