• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk ObjectARX
    Active Member
    Help Me Insert Block
    190 Views, 7 Replies
    11-21-2012 12:10 AM
    Hi everyone!
    I'm coding for Insert Block from file DWG to Current Drawing autocad. But error.
    anyone Modify my code
    void Block()
    ACHAR* szName = _T("luanuoc");
    ACHAR *fileName = _T("C:\\procad\\dwg\\luanuoc.dwg");
    AcDbDatabase *pDb = acdbHostApplicationServices()->workingDatabase();
    AcDbDatabase *pBlockDb = new AcDbDatabase(false,true);
    pBlockDb ->readDwgFile(fileName,_SH_DENYRW,true);
    AcDbBlockTable *BlkTable;
    AcDbObjectId BlkId;
    //AcDbObjectIdArray Ids = new AcDbObjectIdArray();
    //BlkId =pBlockDb ->blockTableId();
    BlkTable ->getAt(ACDB_MODEL_SPACE,BlkId,AcDb::kForRead);
    pDb->insert(BlkId,szName,pBlockDb,true);
    if (BlkTable->has(BlkId))
    ads_point p;
    acedGetPoint(NULL,"Chon diem chen",p);
    AcGePoint3d Inspoint(p[X],p[Y],p[Z]);
    AcDbBlockReference *pBlockobj = new AcDbBlockReference;
    AcDbBlockTableRecord *pBlkTablerec;
    pBlockobj ->setBlockTableRecord(BlkId);
    pBlockobj ->setPosition(Inspoint);
    pBlockobj ->setScaleFactors(1);
    BlkTable ->getAt(ACDB_MODEL_SPACE,pBlkTablerec,AcDb::kForWrite);
    BlkTable ->close();
    pBlkTablerec ->appendAcDbEntity(pBlockobj);
    pBlkTablerec ->close();
    pBlockobj ->close();
    Please use plain text.
    Re: Help Me Insert Block
    11-21-2012 06:18 AM in reply to: xuanhuynh
    What is the error?
    Owen Wengerd
    ManuSoft
    Active Member
    11-21-2012 06:18 PM in reply to: owenwengerd
    Error Insert Block. Can you help me?
    11-21-2012 07:50 PM in reply to: xuanhuynh
    Sorry, I don't understand what the problem is.
    Owen Wengerd
    ManuSoft
    Moderator
    Alexander.Rivilis
    11-22-2012 02:40 AM in reply to: xuanhuynh
    Owen asked you about error code. IMHO it is a Fatal Error because of using non-initialize variable BlkTable in line:
    Пожалуйста не забывайте про Утвердить в качестве решения!Утвердить в качестве решения и Give Kudos!Баллы
    Please remember to Accept Solution!Accept as Solution and Give Kudos!Kudos
    Active Member
    11-23-2012 08:58 PM in reply to: Alexander.Rivilis
    Thanks, I fixed this error.
    But I have this code for create Block with two Attributes. Then Insert this Block into drawing.
    But erro they missing Attributes when i insertBlock:
    1. I use Function TaoBLKDCC2 for create Block and add to Database( this very good)
    2. Then Use function InsertKH1 for Insert Block with name DCC21 into Drawing with two Attributes( this function error, not have attributes
    Can you help me? thank very much!
    void
    ProcadUtil::TaoBLKDCC2()
    AcDbBlockTable *pBlkTbl;
    acdbHostApplicationServices()->workingDatabase() ->getBlockTable(pBlkTbl, AcDb::kForWrite);
    AcDbBlockTableRecord *pBlkTblRcd;
    pBlkTblRcd = new AcDbBlockTableRecord();
    /*char blkName[40];
    if (acedGetString(Adesk::kFalse, "\nNhap ten Block:", blkName) != RTNORM)
    pBlkTbl->close();
    delete pBlkTblRcd;
    return;
    pBlkTblRcd->setName("DCC21");
    AcDbObjectId blkDefId;
    pBlkTbl->add(blkDefId, pBlkTblRcd);
    pBlkTbl->close();
    AcGePoint3d ptStart, ptEnd;
    ptStart =ProcadUtil::smileytongue:olarPoint(AcGePoint3d::kOrigin,3*ProcadUtil::smileytongue:I()/4,1.41421);
    ptEnd =ProcadUtil::smileytongue:olarPoint(ptStart,0,2);
    AcDbLine *pLine1 = new AcDbLine(ptStart, ptEnd);
    ptStart =ProcadUtil::smileytongue:olarPoint(ptEnd,3*ProcadUtil::smileytongue:I()/2,2);
    AcDbLine *pLine2 = new AcDbLine(ptEnd, ptStart);
    ptEnd =ProcadUtil::smileytongue:olarPoint(ptStart,ProcadUtil::smileytongue:I(),2);
    AcDbLine *pLine3 = new AcDbLine(ptStart, ptEnd);
    ptStart =ProcadUtil::smileytongue:olarPoint(ptEnd,ProcadUtil::smileytongue:I()/2,2);
    AcDbLine *pLine4 = new AcDbLine(ptEnd, ptStart);
    ptStart=ProcadUtil::smileytongue:olarPoint(AcGePoint3d::kOrigin,0,1);
    ptEnd =ProcadUtil::smileytongue:olarPoint(ptStart,0,0.68);
    AcDbLine *pLine5 = new AcDbLine(ptStart, ptEnd);
    ptStart=ProcadUtil::smileytongue:olarPoint(AcGePoint3d::kOrigin,ProcadUtil::smileytongue:I()/2,1);
    ptEnd =ProcadUtil::smileytongue:olarPoint(ptStart,ProcadUtil::smileytongue:I()/2,0.68);
    AcDbLine *pLine6 = new AcDbLine(ptStart, ptEnd);
    ptStart=ProcadUtil::smileytongue:olarPoint(AcGePoint3d::kOrigin,ProcadUtil::smileytongue:I(),1);
    ptEnd =ProcadUtil::smileytongue:olarPoint(ptStart,ProcadUtil::smileytongue:I(),0.68);
    AcDbLine *pLine7 = new AcDbLine(ptStart, ptEnd);
    ptStart=ProcadUtil::smileytongue:olarPoint(AcGePoint3d::kOrigin,3*ProcadUtil::smileytongue:I()/2,1);
    ptEnd =ProcadUtil::smileytongue:olarPoint(ptStart,3*ProcadUtil::smileytongue:I()/2,0.68);
    AcDbLine *pLine8 = new AcDbLine(ptStart, ptEnd);
    ptStart=ProcadUtil::smileytongue:olarPoint(AcGePoint3d::kOrigin,0,2.68);
    ptEnd =ProcadUtil::smileytongue:olarPoint(ptStart,0,8);
    AcDbLine *pLine9 = new AcDbLine(ptStart, ptEnd);
    AcGeVector3d vecNormal(0, 0, 1);
    AcDbCircle *pCircle = new AcDbCircle(AcGePoint3d::kOrigin,vecNormal, 0.1);
    AcGePoint3d BasePoint = ProcadUtil::asAc3d(ptStart);
    AcDbAttributeDefinition *pAttDef1 = new AcDbAttributeDefinition;
    //pAttDef1->setPosition(ProcadUtil::smileytongue:olarPoint(ptStart,ProcadUtil::smileytongue:I()/2,0.5));
    ptStart = ProcadUtil::smileytongue:olarPoint(BasePoint,ProcadUtil::smileytongue:I()/2,0.5);
    pAttDef1->setPosition(ptStart);
    pAttDef1->setPrompt("TENDIEM");
    pAttDef1->setTag("TENDIEM");
    //pAttDef1->setTextStyle(_T("chudcc2"));
    pAttDef1->setHeight(2);
    //pAttDef1->setAlignmentPoint()
    pAttDef1->setHorizontalMode(AcDb::TextHorzMode::kTextLeft);
    pAttDef1->setVerticalMode(AcDb::TextVertMode::kTextBase);
    pAttDef1->setLayer("TenDiem");
    AcDbAttributeDefinition *pAttDef2 = AcDbAttributeDefinition::cast(pAttDef1->clone()) ;
    ptStart = ProcadUtil::smileytongue:olarPoint(BasePoint,3*ProcadUtil::smileytongue:I()/2,2.5);
    pAttDef2->setPosition(ptStart);
    pAttDef2->setPrompt("DOCAO");
    pAttDef2->setTag("DOCAO");
    //pAttDef1->setTextStyle("chudcc2");
    pAttDef2->setHeight(2);
    pAttDef2->setHorizontalMode(AcDb::TextHorzMode::kTextLeft);
    pAttDef2->setVerticalMode(AcDb::TextVertMode::kTextBase);
    pAttDef2->setLayer("DoCao");
    AcDbObjectId entId;
    pBlkTblRcd->appendAcDbEntity(entId, pLine1);
    pBlkTblRcd->appendAcDbEntity(entId, pLine2);
    pBlkTblRcd->appendAcDbEntity(entId, pLine3);
    pBlkTblRcd->appendAcDbEntity(entId, pLine4);
    pBlkTblRcd->appendAcDbEntity(entId, pLine5);
    pBlkTblRcd->appendAcDbEntity(entId, pLine6);
    pBlkTblRcd->appendAcDbEntity(entId, pLine7);
    pBlkTblRcd->appendAcDbEntity(entId, pLine8);
    pBlkTblRcd->appendAcDbEntity(entId, pLine9);
    pBlkTblRcd->appendAcDbEntity(entId, pCircle);
    pBlkTblRcd->appendAcDbEntity(entId, pAttDef1);
    pBlkTblRcd->appendAcDbEntity(entId, pAttDef2);
    pLine1->close();
    pLine2->close();
    pLine3->close();
    pLine4->close();
    pLine5->close();
    pLine6->close();
    pLine7->close();
    pLine8->close();
    pLine9->close();
    pCircle->close();
    pAttDef1->close();
    pAttDef2->close();
    pBlkTblRcd->close();
    //Ham convert diem ads_point -> AcGePoint3d
    AcGePoint3d
    ProcadUtil::asPnt3d(ads_point &pt)
    AcGePoint3d pInsert;
    pInsert[X] = pt[X];
    pInsert[Y] = pt[Y];
    pInsert[Z] = pt[Z];
    return(pInsert);
    AcGePoint3d
    ProcadUtil::smileytongue:olarPoint(const AcGePoint3d& pt, double angle,double distance)
    ads_point ptForm, ptTo;
    ptForm[X] = pt.x;
    ptForm[Y] = pt.y;
    ptForm[Z] = pt.z;
    acutPolar(ptForm, angle, distance, ptTo);
    return ProcadUtil::asPnt3d(ptTo);
    double
    return 4 * atan(1.0);
    AcGePoint3d
    ProcadUtil::asAc3d(const AcGePoint3d& pt)
    AcGePoint3d p1;
    p1[X]=pt[X];
    p1[Y]=pt[Y];
    p1[Z]=pt[Z];
    return p1 ;
    void
    ProcadUtil::InsertKH1(TCHAR *szBlock, TCHAR *szDwg, double x, double y, double elev,int stt, double Tile,double goc)
    AcGePoint3d Inspoint(x,y,elev);
    AcDbBlockTable *pBlkTable=NULL;
    AcDbDatabase *pCurDb = NULL;
    AcGeScale3d TileScale(Tile,Tile,Tile);
    pCurDb = acdbHostApplicationServices()->workingDatabase();
    pCurDb ->getSymbolTable(pBlkTable,AcDb::kForRead);
    AcDbObjectId BlkId;
    pBlkTable ->getAt(szBlock,BlkId);
    if(pBlkTable->has(szBlock))
    pBlockobj ->setScaleFactors(Tile);
    pBlkTable ->getAt(ACDB_MODEL_SPACE,pBlkTablerec,AcDb::kForWrite);
    pBlkTable ->close();
    AcDbObjectId pEntId;
    pBlkTablerec ->appendAcDbEntity(pEntId,pBlockobj);
    AcDbObjectIterator *pBlkRefAttItr=pBlockobj->attributeIterator();
    for (pBlkRefAttItr->start(); !pBlkRefAttItr->done();pBlkRefAttItr->step())
    AcDbObjectId attObjId;
    attObjId = pBlkRefAttItr->objectId();
    AcDbAttribute *pAtt = NULL;
    Acad::ErrorStatus es = acdbOpenObject(pAtt, attObjId, AcDb::kForRead);
    if (es != Acad::eOk)
    acutPrintf(_T("\nLoi khong mo duoc attribute"));
    delete pBlkRefAttItr;
    continue;
    if (strcmp(pAtt->tag(),"TENDIEM") == 0)
    pAtt->setTextString("DC12");
    if (strcmp(pAtt->tag(),"DOCAO:") == 0)
    pAtt->setTextString("12.63");
    pBlockobj->appendAttribute(pAtt);
    pAtt->close();
    pBlockobj->close();
    Moderator
    Alexander.Rivilis
    11-24-2012 10:24 AM in reply to: xuanhuynh
    You forgot after creation AcDbBlockReference add all AcDbAttribute's to it (with help of AcDbAttribute::setAttributeFromBlock method)
    Active Member
    11-25-2012 07:46 AM in reply to: xuanhuynh
    I Fixed this error.
    Thank you very much.
