• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk ObjectARX
    Active Member
    Generate large amounts of AcDbText, then AutoCAD show fatal error
    226 Views, 10 Replies
    03-25-2012 08:31 PM
    when I create three million AcDbText and add them to model space, in this process, AutoCAD show fatal error warning, then AutoCAD collapse.
    why?, what can i do for this?
    Please use plain text.
    Valued Contributor
    Nick1983
    Re: Generate large amounts of AcDbText, then AutoCAD show fatal error
    03-26-2012 12:24 AM in reply to: zero111
    put your code here. It can be your bug.
    #define QUESTION(b) (2*b)||(!(2*b)) © William Shakespeare
    Active Member
    03-26-2012 03:03 AM in reply to: zero111
    BOOL AddToModelSpace(AcDbEntity *pEnt)
     if(pEnt == NULL)
        return FALSE;
     AcDbBlockTable *pTable = NULL;
     Acad::ErrorStatus es = acdbHostApplicationServices()->workingDatabase()->getBlockTable(pTable, AcDb::kForRead);
     AcDbBlockTableRecord *pRecd = NULL;
     es = pTable->getAt(ACDB_MODEL_SPACE, pRecd, AcDb::kForWrite);
     es = pRecd->appendAcDbEntity(pEnt);
     pTable->close();
     pRecd->close();
     pEnt->close();
     return TRUE;
    void cmdTest()
       for(long m=0L; m<1500L; m++){
           for(long j=0L; j<2000L; j++){
              AcDbText *pText = new AcDbText(AcGePoint3d(m*100,j*100,0), _T("abc"));
              pText->setColorIndex(1);
              if(AddToModelSpace(pText)==FALSE){
                if(pText != NULL)
                   delete pText;
    Valued Contributor
    Nick1983
    03-26-2012 04:12 AM in reply to: zero111
    your code works fine, BUT...
    when it was done 86%, I got a message, that I have not enough memory to complete task.
    So, I think that your computer is not good enough for this task such as my :smileyhappy:
    PS: I didn't got a fatal error at all
    AcApDocument * pDoc = acDocManager->mdiActiveDocument();
    acDocManager->lockDocument(pDoc);
    acedSetStatusBarProgressMeter(_T("Press ESC to abort: "), 0, 1500);
              if(pText != NULL)
                delete pText;
       acedSetStatusBarProgressMeterPos( m );
       if(acad_abortCycle(_T("\nINFO: aborted...")) == 1)
          break;
    acedRestoreStatusBar();
    acDocManager->unlockDocument(pDoc);
    int acad_abortCycle(const ACHAR * abortString)
       int res = 0;
       CWinApp *app = acedGetAcadWinApp();
       CWnd *wnd = app->GetMainWnd ();
       MSG msg;
       while (:: PeekMessage (&msg, wnd->m_hWnd, 0, 0, PM_NOREMOVE))
          if (!app->PumpMessage())
             :: PostQuitMessage(0);
                break;
       LONG lIdle = 0;
       while (app->OnIdle (lIdle++));
       res = acedUsrBrk();
       if(res == 1 && abortString != NULL) acutPrintf(abortString);
       return res;
    Active Member
    03-26-2012 06:55 PM in reply to: zero111
    How much capacity in your computer memory?
    Valued Contributor
    Nick1983
    03-27-2012 12:01 AM in reply to: zero111
    2GB.
    But free memory, that can be used is little more then 1.2GB (Windows, antivirus, e.t.c eat 800MB)
    03-27-2012 01:45 AM in reply to: zero111
    try to turn off UNDO-recording, that will save a lot of memory as AutoCAD does not need to save every single add-task.
    _UNDO _AUTO _OFF
    - alfred -
    Alfred NESWADBA
    Active Member
    03-27-2012 02:17 AM in reply to: alfred.neswadba
    when it was done 59%, I got a fatal error message .
    if I stop at 58%, then all AcDbText are created in  model space, But if click "ZOOM" or "REGEN" in command line, AutoCAD show fatal error and collapse.  It looks like refresh graphics display make it.
    Valued Contributor
    Nick1983
    03-27-2012 04:32 AM in reply to: zero111
    did you test this in pure autocad? if no, try to unload everything additional (arx-files, lisp and so on) and leave just pure acad, like after installation. I didn't get fatal error. It was a messagebox with Ok|Cancel buttons for aborting the task. So, the problem can be in other arx file :smileyhappy:, if it has, db  reactor, for example.
    And what about Alfred's advice? It will reduce the memory usage.
    PS: try to do the same with, for example, points or lines (to check is this text bug or just lack of memory)
    PS: if it was a pure autocad, may be it's time to reinstall it :smileyhappy:
    Active Member
    03-28-2012 03:12 AM in reply to: Nick1983
    in pure autocad, it outputs more AcDbText, but cmmand "zoom" and "regen" still lead to error or enough memory .
    turn off UNDO-recording, not solve the problem.
    points or lines has no problem.
    It looks like  lack of memory, I'm not sure.
