• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk ObjectARX
    Determine AutoCAD Type
    221 Views, 6 Replies
    09-06-2006 07:13 AM
    Hi all,
    is there a possibility to determine what type of AutoCAD is running? Standard AutoCAD or Map3D or Civil3D or whatever? I already drag the version info from the currently running acad.exe file, but there is to information about the AutoCAD type saved in the version info. I could parse the path, but that's not a solution for me since everyone can change the pathname to whatever he likes.
    Any ideas?
    Thanks in advance!
    Cheers, Hannes
    Please use plain text.
    Distinguished Contributor
    Re: Determine AutoCAD Type
    09-06-2006 08:58 AM in reply to: schneider
    Hannes,
    Its in the registry:
    HKLM\Software\Autodesk\R**.*\ACAD-****:***\ProductName
    *Deelip Menezes
    09-06-2006 09:15 AM in reply to: schneider
    How about the AutoCAD _VERNUM variable?
    Deelip Menezes
    wrote in message news:5319201@discussion.autodesk.com...
    Hi all,
    whatever he likes.
    Any ideas?
    Thanks in advance!
    Cheers, Hannes
    09-06-2006 09:54 AM in reply to: schneider
    It's code maybe useful for you:
    [code]
    static public void AInfo()
    Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
    string AcadVer = Autodesk.AutoCAD.ApplicationServices.Application.Version.ToString();
    ed.WriteMessage("\nAcadVersion: {0}", AcadVer);
    string ProductKey = Autodesk.AutoCAD.Runtime.SystemObjects.DynamicLinker.ProductKey;
    ed.WriteMessage("\nProductKey: {0}", ProductKey);
    RegistryKey key = Registry.LocalMachine.OpenSubKey(ProductKey);
    string ProductName = key.GetValue("ProductName").ToString();
    ed.WriteMessage("\nProductName: {0}", ProductName);
    string ProductId = key.GetValue("ProductId").ToString();
    ed.WriteMessage("\nProductId: {0}", ProductId);
    string ProductCode = key.GetValue("ProductCode").ToString();
    ed.WriteMessage("\nProductCode: {0}", ProductCode);
    [/code]
    In ObjectARX you can use:
    AcDbHostApplicationServices::getRegistryProductRootKey()
    AcDbHostApplicationServices::smileytongue:roduct()
    and so on. Message was edited by: Alexander Rivilis
    09-07-2006 01:56 AM in reply to: schneider
    Thanks for all replies. I've found a way to definitely distinguish between different AutoCAD releases and versions. For those also facing this problem, here is the way to go:
    CString regRootKey = acdbHostApplicationServices()->getRegistryProductRootKey();
    CRegistry reg;
    reg.Open(HKEY_LOCAL_MACHINE, regRootKey, KEY_READ);
    TCHAR buf[200];
    ULONG bufSize = 200;
    reg.QueryStringValue(_T("ProductName"), buf, &bufSize);
    reg.Close();
    Now buf is "AutoCAD 200x" for standard AutoCAD-Releases, "Autodesk Map 3D 200x" for Map3D, "Autodesk Civil 3D 200x" for Civil3D and so on.
    Thanks everyone for pointing me to the right direction.
    Cheers, Hannes.
    Active Contributor
    09-13-2012 05:43 AM in reply to: schneider
    What is this: CRegistry ??
    error C2065: 'CRegistry' : undeclared identifier
    Moderator
    Alexander.Rivilis
    09-15-2012 07:48 AM in reply to: ZK_BUDiKOM
    Registry Wrapper Class (CRegistry)
    Пожалуйста не забывайте про Утвердить в качестве решения!Утвердить в качестве решения и Give Kudos!Баллы
    Please remember to Accept Solution!Accept as Solution and Give Kudos!Kudos
