• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk ObjectARX
    Member
    quanghung1020
    Create ToolBars in Autocad
    248 Views, 2 Replies
    06-24-2011 01:06 PM
    Hi everyone! I have a custom entity. I have created a command "DRAW" to draw the custom entity but now i want to create a toolbar on Autocad. When botton of the toolbar is clicked, the command is excuted. I search to learn on google but don't understand. Please help me, thanks!
    Please use plain text.
    Moderator
    Alexander.Rivilis
    Re: Create ToolBars in Autocad
    06-25-2011 01:13 AM in reply to: quanghung1020
    There are few method of creating toolbar. It is a method of creating toolbar with ActiveX-model of AutoCAD: http://forums.autodesk.com/t5/Autodesk-ObjectARX/New-ToolBar-sample/m-p/1667385#M20461
    Also you can look function CreateToolbars (file samples\entity\polysamp\polymnu.cpp within ObjectARX SDK).
    Пожалуйста не забывайте про Утвердить в качестве решения!Утвердить в качестве решения и Give Kudos!Баллы
    Please remember to Accept Solution!Accept as Solution and Give Kudos!Kudos
    ADN Support Specialist
    06-25-2011 10:11 AM in reply to: quanghung1020
    Or you can create a partial CUI to define your toolbars/ribbon elements.
    Cheers,
    Stephen Preston
    Autodesk Developer Network
    Cheers,
    Stephen Preston
