• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk ObjectARX
    Convert ads_name to VLA-Object from C++ARX?
    200 Views, 4 Replies
    01-06-2013 07:51 AM
    Hello...
    Title:  Convert ads_name to VLA-Object from C++ARX?
    I  want a function convert "vlax_ename2vla_objectC"
    The "vlax_ename2vla_objectC",will convert "ads_name" to "vla-object"
    You replace the "????" with your source C++ARX.
    I need only VisualC++ARX
    I need one function ads_retVLA_object(rr);
    The function "vlax_ename2vla_objectC" return value idem with llisp:
    (type (vlax-ename->vla-object (car (entsel)))
    Please help me...!
    [source=vlisp]
    (Defun vlax_ename2vla_objectL(arg1_as_RTENAME / rr)
      (setq g (type arg1_as_RTENAME))
      (setq rr (vlax-ename->vla_objectarg1_as_RTENAME )
    rr)
    [/source=vlisp]
    [source=cpp]
    :smileytongue:
    int
    /*FCN*/vlax_ename2vla_objectC()
        struct resbuf *pArgs =acedGetArgs ();
        if(!pArgs)
          return acedRetNil();
         if(pArgs->restype != RTENAME)
        AcDbObjectId id;
        if(acdbGetObjectId(id,pArgs->resval.rlname) != Acad::eOk)
       ads_retVLA_object(VLA-OBJECT)
    [/source=cpp]
    [source=virtualC+lisp]
    (Defun vlax_ename2vla_objectC2012(a008 / e rr g j)
    /*c2s: rr=nil,
           g=(listp(e)&&(e!=nil))?dfn_ent_dxf_01(e):a008,
           e=(type(g)==quote(ENAME))?g:nil,
           j= (type(a008) == quote(VLA_OBJECT));
           if (e)
               rr=vlax.ename->vla_object(e);
           else
               { if (j) rr=a008;
                       else  alert("a008errC");
    rr)
    [/source=virtuaC+lisp]
    Please use plain text.
    ADN Support Specialist
    Balaji_Ram
    Re: Convert ads_name to VLA-Object from C++ARX?
    01-15-2013 07:28 AM in reply to: diagodose2009
    Have you tried using the "ObjectIdToObject" method in the IAcadDocument interface ?
    This will provide you with a pointer to the COM Interface (Ex : IAcadCircle) for the ObjectId that you pass to it as parameter.
    You can find it under <ObjectARX folder>\samples\com\AsdkMfcComSamp_dg\CAcadDocument.h.
    Hope this helps.
    Balaji
    Developer Technical Services
    Autodesk Developer Network
    Moderator
    Alexander.Rivilis
    01-15-2013 07:44 AM in reply to: Balaji_Ram
    Hi, Balaji!
    But how can return this pointer from arx to lisp? IMHO it is impossible.
    Пожалуйста не забывайте про Утвердить в качестве решения!Утвердить в качестве решения и Give Kudos!Баллы
    Please remember to Accept Solution!Accept as Solution and Give Kudos!Kudos
    Balaji_Ram
    01-15-2013 08:09 AM in reply to: Alexander.Rivilis
    Hi Alexander,
    I am not sure if the developer wants to pass it over to Lisp, because in that case the "vlax-ename->vla-object" would get the vla-object.
    I thought the developer wanted to get the COM object using an ObjectId using C++ alone and had provided the Lisp code as a demonstration of what he wanted to do.
    Sorry, but I might be wrong in understanding the question.
    Balaji
    Moderator
    Alexander.Rivilis
    01-15-2013 09:17 AM in reply to: Balaji_Ram
    Hi, Balaji!
    diagodose2009 try to develop lisp to arx compiler/converter. It is understandable on the questions which he regularly gives on this forum. That is why hi try to emulate (vlax-ename->vla-object) lisp-function with ObjectARX code.
