Autodesk ObjectARX
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Can someone give me a XData example ?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I am learning XData, and there is several things i do not understand about it. The help file is not much of a help, so can someone please give me an example to create a simple (string/integer type) Xdata, that would be a big help
Or at the very least, please tell me how to check if a XData is working or not. Right now, i got some code without bug, but I do not know this is because i got the code right or simply forgot to add some critical line.
Re: Can someone give me a XData example ?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The ObjectARX SDK has a sample specifically for XData, and parts of that sample are in the Developer's Guide.
The sample is located in samples\database\xdata_dg.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
This example seem to be written for VS 2003 , so when i try to build it with VS2005 or VS2008, it got an error LNK1104: cannot open file 'mfc70.lib'. And since I can not downgrade my VS any further, so testing is not possible now.
Beside, this example create a Xdata with both CString variable. Is it possible to add 1 integer variable into the same XData ?
Thanks in advance !
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Which ObjectARX SDK version do you have? I'm using what will be the 2013 ObjectARX SDK and when I build the xdata sample using VS 2010, I don't get any errors and I don't have an mfc70.lib on my machine.
Sure you can add an integer as well as a string. I haven't tested this, but something like it should work. The lines up to the assert(err == 0); are from the sample. I just added the three lines at the end.:
// Add user-specified string to the xdata.
pTemp->rbnext = acutNewRb(AcDb::kDxfXdAsciiString);
pTemp = pTemp->rbnext;
const size_t nSize = _tcslen(resString) + 1;
pTemp->resval.rstring
= (TCHAR*) malloc(nSize * sizeof(TCHAR));
errno_t err = _tcscpy_s(pTemp->resval.rstring, nSize, resString);
assert(err == 0);
pTemp->rbnext = acutNewRb(AcDb::kDxfXdInteger32);
pTemp->resval.rlong = 146; // or whatever 32-bit int value you want
