[C#] Problem Rotate Circle or Arc with DrawJig
Hi everybody, i wrote this class here because i need to rotate a list of entity but i can't understand why it doesn't work if in the list there's an arc or a circle. The same thing append if i rotate a blockreference and one of the entity of the pointed block is an arc or a circle. thanks everybody!
class JigRotateObj : DrawJig
Point3d _basePoint;
Point3d oldPoint;
Ray _firstAxis;
Ray _lastAxis;
double firstAngle;
double lastAngle;
double angleToDo;
double angleDone;
public int currentInputValue
get;
set;
public List<ObjectId> _toRotate
get;
set;
public JigRotateObj(List<ObjectId> toRotate,Point3d basePoint,Ray firstAxis,Ray lastAxis)
angleDone = 0;
angleToDo = 0;
oldPoint = Point3d.Origin;
_toRotate = toRotate;
currentInputValue = 1;
_firstAxis = firstAxis;
_firstAxis.BasePoint = basePoint;
_lastAxis = lastAxis;
_lastAxis.BasePoint = basePoint;
_basePoint = basePoint;
protected override bool WorldDraw(Autodesk.AutoCAD.GraphicsInterface.WorldDraw draw)
if (currentInputValue == 1)
draw.Geometry.Draw(_firstAxis);
else
draw.Geometry.Draw(_lastAxis);
Transaction trans = AcadUtilities.GetActiveDatabase().TransactionManager.StartTransaction();
Entity app;
foreach (ObjectId obj in _toRotate)
app=(Entity)trans.GetObject(obj,OpenMode.ForWrite);
app.TransformBy(Matrix3d.Rotation(angleDone, Vector3d.ZAxis, _basePoint));
app.TransformBy(Matrix3d.Rotation(-angleToDo, Vector3d.ZAxis, _basePoint));
draw.Geometry.Draw(app);
angleDone = angleToDo;
trans.Commit();
trans.Dispose();
return true;
protected override SamplerStatus Sampler(JigPrompts prompts)
PromptPointResult ppr;
ppr = prompts.AcquirePoint("Insert first point");
if (ppr.Value.DistanceTo(oldPoint) < 0.01||ppr.Value.DistanceTo(_firstAxis.BasePoint)<0.01)
return SamplerStatus.NoChange;
if (ppr.Status == PromptStatus.OK)
_firstAxis.SecondPoint = ppr.Value;
oldPoint = ppr.Value;
firstAngle = new Line(_basePoint, ppr.Value).Angle;
else
ppr = prompts.AcquirePoint("Insert last point");
if (ppr.Value.DistanceTo(oldPoint) < 0.01 || ppr.Value.DistanceTo(_lastAxis.BasePoint) < 0.01)
_lastAxis.SecondPoint = ppr.Value;
lastAngle = new Line(_basePoint, ppr.Value).Angle;
angleToDo = firstAngle - lastAngle;
return SamplerStatus.OK;
Balaji_Ram
In the code snippet that you have shared, I see that you are using the original entity to transform it from the "WorldDraw" method. This complicates the logic to correctly transform since the entity is already transformed and you only need to consider the incremental angle. I see you have two transformation to handle this situation. Instead you could just use a clone which will always be at the original position as that of the entity. So this simplifies your logic quite a bit. I dont see any other issue why this code would not work with circles. Here is the sample code that I used to test it for jigging with circles and it worked ok. In this code, the cloned entity is jigged :
		Point3d _basePoint;
		Point3d oldPoint;
		Ray _firstAxis;
		Ray _lastAxis;
		double firstAngle;
		double lastAngle;
		double angleToDo;
		double angleDone;
			get;
			set;
			get;
			set;
		public JigRotateObj(List<ObjectId> toRotate, Point3d basePoint, Ray firstAxis, Ray lastAxis)
			angleDone = 0;
			angleToDo = 0;
			else
				Document doc = Application.DocumentManager.MdiActiveDocument;
				Database db = doc.Database;
				using (Transaction tr = db.TransactionManager.StartTransaction())
						Entity app = tr.GetObject(obj, OpenMode.ForRead) as Entity;
						Entity clone = app.Clone() as Entity;
						clone.TransformBy(Matrix3d.Rotation(-angleToDo, Vector3d.ZAxis, _basePoint));
						draw.Geometry.Draw(clone);
					tr.Commit();
			return true;
				if (ppr.Value.DistanceTo(oldPoint) < 0.01 || ppr.Value.DistanceTo(_firstAxis.BasePoint)<0.01)
			else
		[CommandMethod("TestJig")]
		static public void TestJig()
			Editor ed = doc.Editor;
			PromptEntityOptions peo = new PromptEntityOptions("\nSelect a circle:");
			peo.SetRejectMessage("\nMust be a circle...");
			peo.AddAllowedClass(typeof(Circle), false);
			PromptEntityResult per = ed.GetEntity(peo);
			if (per.Status != PromptStatus.OK)
				return;
			List<ObjectId> oids = new List<ObjectId>();
			oids.Add(per.ObjectId);
			Ray firstAxis = new Ray();
			firstAxis.BasePoint = Point3d.Origin;
			firstAxis.SecondPoint = new Point3d(10, 0, 0);
			Ray lastAxis = new Ray();
			lastAxis.BasePoint = Point3d.Origin;
			lastAxis.SecondPoint = new Point3d(0, 10, 0);
			JigRotateObj drawJig = new JigRotateObj(oids, Point3d.Origin, firstAxis, lastAxis);
			drawJig.currentInputValue = 1;
			PromptResult promptResult = Application.DocumentManager.MdiActiveDocument.Editor.Drag(drawJig);
			drawJig.currentInputValue = 2;
Balaji
Developer Technical Services
Autodesk Developer Network
