AutoCAD API error!
AutoCAD API error!
AutoCAD API error!
I am getting following error while applying stretch command to my custom entity.(Only for AutoCAD 2004)
Error :This drawing contains entities that do not adhere to the AutoCAD graphics API.
Geometry was received without a preceding SubentityMarker. Entities that wish to make sure of SubentityMarkers (i.e. - custom AcGi entities) should send down a SubentityMarker before sending down any geometry
Can anybody tel me, is this AutoCAD's error or am i doing something wrong with custom entity?
Can you post the code from your custom entity's worldDraw/viewportDraw override(s)? You may be doing exactly what it says you're doing, i.e. sending geometry before setting a gs marker, but I 'm not sure since I don't have any of your code to look at.
Thanks Andy!
It worked now. I haven't set setSelectionMarker in worldDraw().
Im getting the same error. How do I fix it?????
