AcGs question
AcGs question
AcGs question
I have a modal dialog with a list. When I select a list item, I do the
following:
m_pGSManager = acgsGetGsManager(acedGetAcadDwgView());
m_pGSDevice = m_pGSManager->getGUIDevice();
m_pGSView = m_pGSManager->getGSClassFactory()->createView();
resbuf wcs, ccs, dcs;
wcs.restype = RTSHORT;
wcs.resval.rint = 0;
ccs.restype = RTSHORT;
ccs.resval.rint = 1;
dcs.restype = RTSHORT;
dcs.resval.rint = 2;
resbuf rb,rbVMin,rbVMax;
AcGeVector3d viewDir;
AcGePoint3d cenPt,vsMin,vsMax;
acedGetVar("VSMIN", &rbVMin);
acedTrans(rbVMin.resval.rpoint, &ccs, &wcs, 0, asDblArray(vsMin));
acedGetVar("VSMAX", &rbVMax);
acedTrans(rbVMax.resval.rpoint, &ccs, &wcs, 0, asDblArray(vsMax));
cenPt = AcGeLineSeg3d(vsMin,vsMax).midPoint();
acedGetVar("VIEWDIR", &rb);
acedTrans(rb.resval.rpoint, &ccs, &wcs, 0, asDblArray(viewDir));
m_pGSView->setView(cenPt+viewDir,cenPt,viewDir,vsMax.x-vsMin.x,vsMax.y-vsMin
.y);
m_pConnectionMarker = new
AcDbBlockReference(AcGePoint3d::kOrigin,m_idOfConnectionMarkerBlock); //
m_idOfConnectionMarkerBlock is in the current dwg and valid
m_pConnectionMarker->setPosition(m_pListOfItems->connectionPoint(l_hItem));
// the point is on the screen. I'm sure.
m_pGSView->add(m_pConnectionMarker,m_pGSManager->getDBModel());
m_pGSDevice->add(m_pGSView);
m_pGSView->invalidateCachedViewportGeometry();
m_pGSView->invalidate();
m_pGSManager->getDBModel()->invalidate(AcGsModel::kInvalidateAll);
The block not displayed.
How can I display a non-database resident entity (a drawable) using the GS
system?
The blockview sample doesn't help.
Any idea? Or a code snippet?
Thanx
Just a thought...
I would think you should use a jig, may be that's a bit out of the way but
only the jig is able to display non db-resident ents.
Otherwise you could temporarily add an entity - display it and then erase it
again.
Jörg
"Török Zoltán" schrieb im Newsbeitrag
news:50B77C1FF875B5A8D77DC9F2C580A6E5@in.WebX.maYIadrTaRb...
> Hello,
> following:
> .y);
> system?
> Thanx
> Zé
"J. Schlingheider" wrote
> Just a thought...
it
> again.
> Jörg
No, it's not a jig.
I have a !! modal dialog !!. When the user selects an element, it zooms
(works fine) to that and
put a mark around that item on acad drawing area.
Now I have to insert a block and update its position.
Its working, but not an elegant solution (it unnecessarily modifies the dwg)
Unfortunately the GS system not well documented enough.
With the GS you can use a AcGsView (like the UCS icon or the orbit does)
to display a "drawable".
So I'm waiting for Autodesk, to give us just a litle bit deeper
documentation.
Or trying, trying, trying and getting balder and balder.
I have successfully added non-DBR entities to an AcGsView using the
following initialization:
m_Device = m_GsManager->createAutoCADDevice(m_hWnd);
// a simple view
m_View = m_GsFactory->createView();
// a model with open/close protocol
m_Model = m_GsManager->createAutoCADModel();
m_Device->add(m_View);
| Byron Blattel
| CADwerx---Applications for AutoCAD
| Autodesk Registered Developer
| email: byron@cadwerx.net
| web site: http://www.cadwerx.net
"Török Zoltán" wrote in message
> Hello,
> following:
> .y);
> system?
> Thanx
> Zé
Easy on your scalp 🙂
// a simple view
| Byron Blattel
news:64E8F8493AA361231DE30DB49D88F84C@in.WebX.maYIadrTaRb...
> > Just a thought...
but
erase
> it
> > again.
> > Jörg
> No, it's not a jig.
dwg)
> documentation.
> Zé
The original of this message with attached file has been moved to
the Customer Files area
(news://discussion.autodesk.com/autodesk.autocad.customer-files
or http://discussion.autodesk.com/WebX?14@@.ee940b5). Please do
not post files or graphics in product support groups.
See the newsgroup guidelines at
http://discussion.autodesk.com/webx?groundrules.
Anne Brown
Manager, Moderator
Autodesk Product Support discussion groups
Discussion Q&A: http://www.autodesk.com/discussion
Subject:
Re: AcGs question
Date:
Thu, 20 Jun 2002 07:57:38 -0700
"Fenton Webb \(Autodesk\)"
Organization:
autodesk
Newsgroups:
autodesk.autocad.objectarx
Try my version of BlockView...
Enjoy! 😉
CHeers
Fenton Webb
Developer Technical Services
Attachments: _BlockViewV6.zip
