Autodesk ObjectARX
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
AcDbPlotSe ttings paper image origin?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
How do you access AcDbPlotSettings paper image origin from ARX?
AcDbPlotSettings
PaperImageOrigin
dxf code 148,149 x,y
http://docs.autodesk.com/ACD/2011/ENU/filesDXF/WS1
John
Re: AcDbPlotSe ttings paper image origin?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi John,
To retrieve the origin, you can use AcDbPlotSettings::getPlotOrigin().
Plot settings are applied using the AcDbPlotSettingsValidator class. That is where you'll find the set functions corresponding to the get functions you see in AcDbPlotSettings. I've copied below a pertinent example from the ADN website (apologies for the sub-optimal formatting due to copy and paste).
Cheers,
Stephen Preston
Autodesk Developer Network
I want to Window plot a drawing to DWF, I'm using COM to plot the DWF but how do I setup the Plot Settings so that it plots using a couple of Window coordinates?
In ObjectARX you need to use the AcDbPlotSettingsValidator class to setup the Plot. Here is some code which shows you what to do. Note this is using the Window coordinates as the extents of the drawing. This is purely for test purposes - if you want to plot the extents then use setPlotType (pLayout, AcDbPlotSettings::kExtents). There is also a Visual LISP example following the ObjectARX code.
#import "acad.tlb" no_namespace
static void ASDKTS66871_PlotWindow_COM_testPlot(void)
// Use ActiveX interface to get the application object
IAcadApplicationPtr pAcad = acedGetAcadWinApp()->GetIDispatch(TRUE);
//get the path to plotter configuration
_bstr_t szPrinterPath;
szPrinterPath = pAcad->Preferences->GetFiles()->GetPrinterConfigPa
// get the current database
AcDbDatabase *curDocDB = acdbHostApplicationServices()->workingDatabase();
// get a pointer to the layout manager
AcApLayoutManager *pLayoutManager = (AcApLayoutManager *)acdbHostApplicationServices()->layoutManager();
const ACHAR *layoutName = pLayoutManager->findActiveLayout (true);
// get the current layout
AcDbLayout *pLayout = pLayoutManager->findLayoutNamed (layoutName, true);
// if we got it ok
if (pLayout != NULL)
Acad::ErrorStatus es;
// get the plotsetttings class
AcDbPlotSettingsValidator *pPlotSettingsValidator = acdbHostApplicationServices()->plotSettingsValidat
// if we got it ok
if (pPlotSettingsValidator != NULL)
// Refresh the layout lists in order to use it
pPlotSettingsValidator->refreshLists (pLayout);
// change the current layout plotter
es = pPlotSettingsValidator->setPlotCfgName (pLayout, szPrinterPath);
// set the window to plot as the extents of the drawing
es = pPlotSettingsValidator->setPlotWindowArea (pLayout,
curDocDB->extmin ().x,
curDocDB->extmin ().y,
curDocDB->extmax ().x,
curDocDB->extmax ().y);
// set the orgin
es = pPlotSettingsValidator->setPlotOrigin (pLayout,
curDocDB->extmin ().y);
// set to plot centred
es = pPlotSettingsValidator->setPlotCentered (pLayout, true);
// setup the plot type to window
es = pPlotSettingsValidator->setPlotType (pLayout, AcDbPlotSettings::kWindow);
// set the scale
es = pPlotSettingsValidator->setStdScaleType (pLayout, AcDbPlotSettings:
tdScaleType::kScaleToFit);
// we have to close the layout here because the last parameter of
// findLayoutNamed is true, leave layout open
pLayout->close ();
// get the current document
IAcadDocumentPtr pDoc = pAcad->GetActiveDocument();
// create a plot object
IAcadPlotPtr pPlot = pDoc->GetPlot();
// lets plot
pPlot->PlotToFile("c:\\test.dwf", szPrinterPath);
Note: You do not need to use COM to plot. Instead you can use ObjectARX functions. A sample ships with the SDK. ( ..\ObjectARX 2009\samples\editor\AsdkPlotAPI )
Here is a Visual LISP example:
(defun c:testPlotWindow ( / acadObject acadDocument activeLayoutObject plt p1 point1
pPt1 pPt1sa pt1 p2 point2 pPt2 pPt2sa pt2 )
(vl-load-com)
(setq acadObject (vlax-get-Acad-object))
(setq acadDocument (vla-get-ActiveDocument acadObject))
(setq activeLayoutObject (vla-Get-ActiveLayout acadDocument))
(setq plt (vla-get-plot acadDocument))
(vla-put-configname activeLayoutObject "DWF6 ePlot.pc3")
(vla-put-canonicalmedianame
activeLayoutObject
"ISO_full_bleed_A3_(420.00_x_297.00_MM)"
(vla-put-paperunits activeLayoutObject acMillimeters)
(vla-put-plotrotation activeLayoutObject ac0degrees)
; How to control the Plot Style Table
; (vla-put-StyleSheet activeLayoutObject "HP LaserJet 4MV.ctb")
(setq p1 (getpoint "\nSelect Window Point No 1 (Lower Left): "))
(setq point1 (list (car p1) (cadr p1)))
(setq pPt1 (vlax-make-safearray vlax-vbDouble '(0 . 1)))
(setq pPt1sa (vlax-safearray-fill pPt1 point1))
(setq pt1 (vlax-make-variant
pPt1sa
(logior vlax-vbarray vlax-vbDouble)
(setq p2 (getpoint "\nSelect Window Point No 2 (Upper Right): "))
(setq point2 (list (car p2) (cadr p2)))
(setq pPt2 (vlax-make-safearray vlax-vbDouble '(0 . 1)))
(setq pPt2sa (vlax-safearray-fill pPt2 point2))
(setq pt2 (vlax-make-variant
pPt2sa
(vla-SetWindowToPlot activeLayoutObject pt1 pt2)
(vla-put-plottype activeLayoutObject acWindow)
(vla-plottofile plt "c:\\test.dwf" "DWF6 ePlot.pc3")
Stephen Preston
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'm looking for "paper image origin" not the "plot origin".
getPlotOrigin() retrieve values for DXF code 46,47
I need the values for DXF code 148,149.
John
