• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk ObjectARX
    Valued Contributor
    AcDbGripData GetGripPoints() confusion......
    100 Views, 2 Replies
    02-07-2012 08:46 AM
    It states in the documentation:
    "The caller is responsible for freeing the AcDbGripData objects whose pointers are in the grips array."
    I am fine with this, but, to do this the array of grip data objects must be stored or cached somewhere in order to be cleaned up. How do you do this when the subGetGripPoints() function is 'const'? Surely a member variable on the custom entity won't suffice.
    Any suggestions?
    Mike
    Please use plain text.
    Re: AcDbGripData GetGripPoints() confusion......
    02-07-2012 09:04 AM in reply to: mbujak
    If the caller is responsible for the AcDbGripData objects, you can't safely cache pointers to their memory (because the caller will delete them, leaving you with pointers to freed memory).
    Owen Wengerd
    ManuSoft
    Owen Wengerd
    ManuSoft
    Valued Contributor
    02-07-2012 09:19 AM in reply to: mbujak
    Ok, so, in the case of subGetGripPoints(...) the caller would be the Autocad framework, so I don't need to worry about the AcDbGripData object pointers themselves... Just any appData structures that I may pass into them.
    Mike
