• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Navisworks
    Valued Mentor
    granite07
    line after break function, in C3D still one line
    279 Views, 4 Replies
    07-24-2012 12:19 PM
    In C3D 2013 I broke a line into three segments, after NWCOUT and opened in Navisworks 2013, the line is again a single line. The line was originally imported from a dgn file. The line is also bundled with several other lines (pipe edge and centerline). In Navisworks they are a 'Line Set'. The common feature is that these four lines are in the same layer.
    Is this normal - is there an easy solition, a checkbox in navisworks for 'recognize breaks'? Can a line set be broken? How do I change the type from line set in C3D to line or similar type?
    I split a project into 'workzones' by drawing rectangular boxes and breaking lines that crossed workzones. The purpose is to sequence the work in 4D.
    Do I have to break each layer into multiple layers, one layer for each workzone? This cannot be right.
    Forest Peterson, granite@stanford.edu; build-sheet
    Please use plain text.
    Employee
    Re: line after break function, in C3D still one line
    08-16-2012 02:18 AM in reply to: granite07
    Hi Forest,
    To keep lines split, there is a global option in the DWG file loader options. It should be a dropdown labelled Line Processing. Selecting Separate All Lines should prevent lines from being merged into Line Sets & become selectable entities in their own right. Please be aware that for large models this can cause the file load to be much slower and/or memory intensive as this option results in a new Selection Tree node for every single line (which is why we usually merge them together).
    Hope that helps,
    Jeff
    Senior Software Engineer
    Navisworks
    Autodesk Ltd.
    Valued Mentor
    granite07
    09-05-2012 11:49 AM in reply to: JeffH_ADSK
    Jeff - what does the as provided optio do compared to seprate all lines.
    I want the line breaks where I placed them in C3D - does "seprate all lines" explode the lines?
    Valued Mentor
    granite07
    09-06-2012 09:29 AM in reply to: granite07
    I have not tried the "seperate all lines" option, the "as provided" option seems to have worked
    Also, I use two computers, and Ivy Bridge quad core 3.6Ghz turbo and an AMD Phenom II 3.6Ghz, comparable RAM and SSD - sometime one works better than the other. In this case the ivy bridge could not build the file with the "as provided" option but the AMD Phenom II did without a problem.
    Valued Mentor
    granite07
    10-03-2012 03:55 PM in reply to: granite07
    searched for why my ivybridge was taking forever to build a navis file from C3D dwg file -> found my own answer from last month... try my AMD workstation.
    note to self, buy new memory :smileyhappy:
